Question about Xerox Phaser 8500/DN Printer
Error code 19,003.48:75856
My printer restarted without prompting and it gives me that error code
  • alina685 Jan 30, 2009
    Thank you
    President:
  • 2,072 Answers
That is a print head calabration fault. 99 percent chance the print head has failed. That would require replacing hte print head.
That is a common problem on the 8500. Look for a dealer in your area if you want to repair is. Xerox will charge over $200 to show up and $750 for the print head.
Posted on Jan 30, 2009
My hp deskjet ink adv2060 K110 not print the spooler service not running?
Hello there Marejen,
See if there is any spooler.exe running in your task manager. Press ctrl, alt + delete to go there. If you see the process, click to highlight then end it. Then restart your computer and the printer itself. Then try to initiate a print again once everything is loaded.
Please let me know if this helps. Thank you for using FixYa.
Aug 02, 2011 | HP Deskjet 2460 InkJet Printer
Error code 016-370 Restart printer If problem
Error code: 016-370
This is yet another error message asking you to restart the printer. You need to switch off the printer and then connect it via the USB cable. Press the hold and cancel buttons simultaneously. Then power on the printer again. On your LCD display you should typically see a message saying 'ready for download mode'. You will then need to initialize the firmware update process. LCD will change to the writing mode. 10 minutes later you will be prompted to start the printer again.
The firmware is available here:
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R148843&SystemID=PRN_LSR_3100CN&servicetag=&os=WLH&osl=en&deviceid=6673&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=0&libid=40&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=197745
May 02, 2011 | Dell 3100cn Laser Printer
Error code 5200 in canon mp276 please solve
Hello
This error is due to the cartridge and nothing else. Just replace the color cartridge and try to use the printer with both (color and black) cartridges. Then it will not give that error again. After installing the cartridges, try to re-install the drivers and restart your system.
Well, I am new to fixya, so please don't forget to appreciate the solution.
Thanks
Jan 27, 2011 | Canon Office Equipment & Supplies
Error code 0xc19a0021
Hello thanks for using fixya
To solve the error code 0xc19a0021. There is following solution.
Follow it step by step
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
By this error will automatically remove. But if u face still this error then printer service required
I hope this solution will helpful 4 u
Please keep thumbs up in do Rating if it is helpful
THANKS & Keep Using fixya
Jan 07, 2011 | HP Photosmart C5180 All-In-One InkJet...
Hello good day printer is saying service transfer unit with error code 90400 machine is totally serviced and vacuumed yet code is still there can you give me the diagonistic code to clear this error.
Hi please uninstall the drivers for the printer and reinstall them again,then restart the computer and see if the error still exist.
Please let me know if you have any questions
Jul 17, 2010 | Office Equipment & Supplies
Print job(s) waiting in queue will not advance to print.
If there are no errors with the printer (offline or other issues), you may have a problem with the spooler. You need to stop and restart the service. One way to do this in Windows is from the Command Prompt (Run As Administrator for Vista or Win7). Start > All Programs > Accessories > Command Prompt (right click on the option to Run as Administrator).
At the first prompt, type "net stop spooler" without the quotes and hit enter. At the next prompt, type "net start spooler" again without the quotes and hit enter. (Type Y if you get a query about the Fax system after the first command.) When the second command completes, reboot the computer and try printing again.
I hope this helps.
Jun 11, 2010 | HP PSC 2175 All-In-One InkJet Printer
Canon iP1800 Service error 5600
step 1: remove printer cable from your printer
step 2: you have to delete any files found in this folder C:\WINDOWS\system32\spool\PRINTERS
step 3: restart computer
May 14, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Easyshere 5300
The error message appears due to a faulty dot net framework installation on the system.
Perform the below mentioned steps in order to fix the issue.
· Uninstall the Dot Net Framework 2.0 from the system from the add/remove programs section in add/remove programs if the OS is XP.
· Else you can also download the Aaron-Stebner's .Net Framework Setup Cleanup Utility from the website: http://www.raymond.cc/blog/archives/2008/12/02/uninstall-microsoft-net-framework -with-aaron-stebner-cleanup-tool/
· On this website, guide the customer click on the Hyperlink [Download .Net Framework Setup Cleanup Utility]
· Save the utility and run it. When given the list of options, choose Dot net framework 2.0.
·Follow the prompts to uninstall the .Net framework 2.0
·Restart the system.
·Download the .Net framework 2.0 from the website:
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5
· When prompted, save the file and then run it. [Don’t try to run the file without saving it; else you would get an error message
Error 0X80131107
Error Code 25015.
·After the installation of the .Net framework 2.0, check the AIO Home Center again.
Best of Luck
Saj
Jul 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Print Error
unplug usb, delete driver and software, download driver and software package from brother web, only connect when prompted.
http://solutions.brother.com/index-asia.html
Sep 05, 2007 | Brother HL 1440 Laser Printer
Xerox Phaser  8500/DN Printer Logo
197 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
