Question about NEC PGA370 SIS620 ATX Motherboard (1510002500)
Don't know which pins to connect the power sw cable to.
Also, the power led, reset sw, hdd led
  • 382 Answers
Here is the Layout and installation of your board. Hope this helps.
http://www.bcmcom.com/tech/SL620/SL620-manual.PDF
Posted on Jan 29, 2009
FX58M powerSW
thank to answer.
@Jorico no threr is nothing wrote on the mobo (expt fp1)
Aug 19, 2012 | Computers & Internet
I just installed my motherboard samsung harappa-4 on new casing, but i don't know how to connect cable for power switch,power led,hdd led, and reset, please give me solution, thankyou very much
LOOK FOR THE FRONT PANEL PIN HEADER.
IT MUST BE SOMEWHERE BY THE EDGE OF THE MB.
THERE ARE MARKINGS LIKE HDD LED, PWR SW ETC.
HOPE THIS HELPS.
Apr 13, 2010 | Computers & Internet
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
How to connect power led ,HDD,Reset,power SW cables in hp motherboard s/n 383620-001
check your motherboard manual if you do not have it go to www.support.hp.com and look for manuals based on the model. this should give you detailed instructions as to which pins you plug those cables into. usually they are located towards the bottom of the motherboard to the right of your PCI Expansion slots
Aug 20, 2008 | HP Computers & Internet
Want to connect my mercury PVM7 PRO MB
what type of motherboard do have? It sud be on right hand-side you will find some pins. USE MEGNIFYING GLASS THERE BE WRITTEN IN SMALL PRINT connect power LED, HDD LED, RESET SW AND POWER SW
Jul 28, 2008 | Computers & Internet
Help me on how to connect my samsung motherboard!
Power>Red & white
Reset>Purple & white
HDD Led>Green+
HDD Led>White-
HDD Tx>Yellow & white
Select each pin & correspond with block on FSB M/B panel
Jan 17, 2008 | Computers & Internet
NEC PGA370 SIS620 ATX Motherboard (1510002500) Logo
255 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
