Samsung SpinPoint P80 SP1604N 160 GB Hard Drive
Problem for Samsung SpinPoint P80 SP1604N 160 GB Hard Drive
MX6L060J3 (Maxtor)
By Russian on Jul 27, 2007
I have the following HD "MX6L060J3" from Maxtor and for some reason I cannot detect it in the bios. I have tried everything.
Jumpers settings are correct.
Cable is checked.
Motherboard is Asus P4P800 SE
I tried to get it working with another HD and without, but nothing helps.
When I start my computer I hear the HD booting up (rattling for couple of sec) and a green light, then the light turns off.
I do not know what is wrong. I have tried to open the HD, but I do not have the screwdriver needed, so that option is out.
What could be the problem?
Solution #1
posted on Jul 28, 2007
Not Rated)
tomj23
Rank: Guru
Rating: 87%, 1832 votes
If you?ve tried another hard drive with the same results it would seem unlikely that both were bad. The more likely candidate is an error in connecting them or a bad motherboard.
Your Maxtor hard drive is an IDE so check the following:
- You have two IDE channels on your board usually marked in some fashion Make sure you are connecting the drive to the primary channel.
- Are you using Master / Slave or cable select to identify your drives? Make sure you are using the correct cable depending on which system you are using.
- Make sure you have jumpered your drive correctly, in your case it should be set as Master or cable select.
- If you are using cable select make sure you have the drive plugged into the correct connector, typically it would be marked drive 1.
By the way home users should not attempt to take apart hard drives. There are no user replaceable parts and all you?ll do is ruin the drive.
Good luck and let us know how it goes.
Was this helpful?
Yes
No
Popular Solutions for Samsung SpinPoint P80 SP1604N
Questions and Unsolved Problems for Samsung SpinPoint P80 SP1604N
Do you recommend Samsung SpinPoint P80 SP1604N 160 GB Hard Drive?
Answer
Answer
What are the cylinder, head and sector setting for a Sansumg SP 1604N hard drive. By Bois does not... (More)
Answer
hi i have a samsung sp1604n hdd and i have clicking/knocking sound i know that the problem is from... (More)
Answer
scan code hd535-4 ran pc doctor hard surface test fail
Describe your Hard Drives problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drive Experts
Top Computer & Laptop Repairmen
in Newport, KY
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
