Question about Kyocera Copystar CS-1820 Black and White Copier
Network/printer issue I am trying to set up a kyocera 1820 on my network. It says it installed successfully, the correct IP address is on the copier but it will not print. How can I trouble shoot what is going on?
  • jschildmeier Jan 29, 2009
    I have done that...it says it is ready and it will not print. The manual says that the DHCP has to be turned off, I turned it off on my copier, how do I turn it off on my computer?
The best thing that you can do is to report it to the branch located nerest to you, or report it to philcopy corporation. one of the distributor of the latter machine.
Posted on Jan 30, 2009
    Genius:
  • 1,605 Answers
Try ping xxx.xxx.xxx.xxx (printer IP address. if you get a answer back (no timeout). then you have a good connection.
go to start>>printer and faxes>> add a printer.
select network pirnter, and let the operating system find the printer.
if it find it, then install the driver on the PC try a test page.
if not, then you have to install the printer as local.
select to creat a new port, with standard TCP/IP port. insert the printer IP address.
install the pirnter driver and try a test page.
Posted on Jan 29, 2009
  • Frank
    Frank Jan 30, 2009
    DHCP is not on your PC it is on the serveror router.
    if you are using one of the PC as printer server, then it need to turn off.
    what kind o fnetwork do you have??
How to connect a Kyocera CS1820 as a network printer
Hook up a cat 5 cable from a network switch and load the driver on each workstation
Jun 19, 2010 | Kyocera Copystar CS-1820 Black and White...
How do I change a password for a scanning folder from a networked kyocera KM4050I
browse the ip address, go to basic settings on the menu go to contacts, access your name and change the password then submit
Jan 26, 2010 | Kyocera Copystar CS-1820 Black and White...
Kyocera cs 1820 error 2102 using ftp
I reset the IP adderss to another printer on the network and it worked so it looks like not all printers are compatable
Jun 17, 2009 | Kyocera Copystar CS-1820 Black and White...
How to put an IP address on the CopyStar CS-1820 printer
putting an ip to 1820, just go to system menu, scroll down look for the network setting, you will find ip address, then fill it up.
Apr 21, 2009 | Copystar CS-1820 Copier
I have a Kyocera CS 1820 copier, scanner, fax machine and I can't figure out how to geet it to scan to pc. I have installed the drivers from the kyocera site and still no luck......
Make sure that you downloaded the correct drivers....Etc... (x64) vs (x86) also make sure you have the proper script # driver ... Etc... #5.1 vs #6. You will want to completely uninstall all the old drivers, shut down your computer --- do not just reboot, reinstall all the new drivers,and after your computer is done rebooting – shut it down and restart. Also make sure that you and the designated file set up on the computer, it needs to know where to scan the document and send it to.
Dec 23, 2008 | Kyocera Copystar CS-1820 Black and White...
KM-1820 scanner setup
The KM-1820 to scan to PC is using SMB, FTP or e-mail.
for SMB:
I am assuming you have the KM-1820 connected within the network and a static IP address for it.
open any Internet browser and go to KM-1820's IP address.
You should see the Command Centre web page.
Go to Basic page and add/register a contact within the Address Book.
Give a name and at the SMB section field, fill up with your computer hostname or the ip address of your computer where you want to scan. Fill up the user name with the local user name - the one what you are using to get into your computer - or create a new LOCAL user for your PC lets say "kyocera". So for SMB will be your computer and username: kyocera. (You will need a password for that computer user (kyocera) ). Then create a folder "scan" where you want ot receive the scanned files and add "scan" at the path field (SMB section of that webpage - command center).
Now share the folder "scan" as "scan".
if you want you can always use the scan to e-mail !! but you need a smtp server. All the settings can be done using that command center webpage.
Dec 08, 2008 | Kyocera Copystar CS-1820 Black and White...
ERROR CODE 2101 WHEN TRYING TO SCAN
you have to have a user name and password set up on the computer you are scanning to then you set theat up in the address you set up on the copier.
Oct 30, 2008 | Kyocera Copystar CS-1820 Black and White...
Error Code 2102
Change the SMTP port from 25 to 587
Oct 21, 2008 | Kyocera Copystar CS-1820 Black and White...
Can't install
If you can ping its IP, you have that part correct.
What you may be having is a firewall issue.
If your firewall protection is not allowing an exception for that IP address, you can ping the machine, yet the data being sent will be blocked.
I have seen this several times in setting up printers, you have to go into your firewall and set up an exception for the IP address on your firewall.
I suspect that is the issue. Not uncommon.
Jan 16, 2008 | Sharp AR-507 Copier
Kyocera-Mita going offline
Try an updated driver from the manufacturer or see if they have any know issues with 2003 sp2 and the driver.
Hope this helps!
Nov 27, 2007 | Kyocera Mita KM-5035 Printer
Kyocera Copystar CS-1820 Black and White Copier Logo
194 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
