Question about Harman Kardon DVD 101 DVD Player
My HK dvd101 player reports "disk error" with every disk
I have a second HK DVD 101 of the same age. It does not have a disk error with any dvd. It (the defective DVD101) sounds as tho it's going through the motions internally, but always fails.
Any ideas guys? I use to work for HK at Madrigal. (Tis why I have two.) I B A Bench tech. I'm looking for a short cut from someone who knows the 101 product. I worked w/ Audio Access product line.
Help !!
Thanks in advance.
BG
Hello Fixya Team,
I've focused in on the location of the problem. ATT, I'm trying to find a replacement input control board from Harmon. Not looking good tho. It acts like a cold solder joint or a flaky connector.
Thanks for getting back to me. If I end up stuck, I'll get back to you.
TKS,
BG
Posted on Feb 02, 2009
All the dvds I insert are reading disk error.
Sounds like it is time for a new unit. your problem is not worth fixing as it is either a failing laser pickup due to age, or the laser beam is caked with tar from smoking.
New blurays are quite inexpensive.
Please dispose of the unit responsibly.
May 09, 2014 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do i set my sony dcr dvd 101 handycam to record on dvd-rw disc
Before using a DVD-RW you must first format the disc.
Here is a link to your manual:
http://www.docs.sony.com/release/DCRDVD101.pdf
Go to page 26 and following for instructions on formatting yor disc.
Thanks for using Fixya.
Mar 05, 2011 | Sony Handycam DCR-DVD101 DVD Camcorder
Its says write error when I go to burn a avi file onto a dvd disc
Is the AVI file less than 4.7 GB in size?
Does the "write error" happen more than once?
Did it happen only with one "blank" disk?
Can you select some other file, and successfully write it to a disk?
How many seconds after clicking "start burn process" does it take before you get the error-message?
After getting the "write-error", look at the disk.
Does it appear that anything has been burned onto the disk?
If you put the disk into some other DVD-reader, is it still reported as 'blank" ?
Jun 12, 2010 | Computers & Internet
The dvd player says it is loading, but then
there are two solutions to that,
firstly open the dvd and check that the disc in side is turning round. if not check the servo control on the card. if it is turning then check the second solution.
secondly, check the senser bulb if its caming on when the disc is turning. this also can be replaced.
thanks finding from fixya.
Jan 31, 2010 | Televison & Video
No disc error
Yes bcoz you need to clean the lens with a lens cleaner CD....
Sep 19, 2009 | Televison & Video
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Dvd player error code h2
On my DVD-LV50, I was able to re-initialize and fix a different error (error code H05). It might work for you, too.
With no disk in the player, press and hold these buttons for 4 seconds:
  1. Back skip -- [ |<< ]
  2. Pause -- [ || ]
  3. Play -- [ > ]
The screen will go blank, then say "Initialized."
After that, it worked like new.
I hope that helps.
Apr 13, 2008 | Panasonic DVD-LV50 Portable DVD Player...
Cant Open the DVD cover
I am curious, did anyone start having this problem after going through x-ray at airport?? We had trouble after that?? I paid a lot of money for this thing and I am ready to smash it hard, real hard!!
Dec 19, 2007 | Sony Handycam DCR-DVD101 DVD Camcorder
DVD 10
It either needs some cleaning to the lens, or it might be that the player can't make the switch to read DVD's. It's my understanding that the laser has to change it's characteristics depending on the media it's reading. I believe what the drive does is try different laser settings (such as beam size, and intensity) until it can read the media. Your player might have a fault with this feature. If opening the player chasis and brushing dust of the lens doesn't fix it, you should take it to a decent lab to get an estimate for repair. It might be minor, as some further cleaning, or it might be more critical, parts replaced etc. Good luck
Jun 05, 2006 | Harman Kardon DVD 101 DVD Player
Harman Kardon DVD 101 DVD Player Logo
347 people viewed this question
Top Harman Kardon Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Harman Kardon Televison and Video Expert? Answer questions, earn points and help others
