Question about Panasonic SC-HT670 System
LOCKED displays when attempting to eject disk from SA-HT670
I have a Panasonic SA-HT670 home theatre. I cannot get any discs to eject. When the change disk, open/close or disk check buttons are pressed, the display says LOCKED. All 5 DVDs that are in there play just fine (so I know they aren't in there crooked or something). I have gone through the menu and don't see an option to lock this. I have looked through the user's manual and don't see it in the trouble shooting section. I have powered the unit off and on, but it still does this. I cannot get any discs in or out! There is currently a DVD in there that belongs to the library and is way overdue. Can you HELP???!!!
  • Herb Lehmann Jul 27, 2007
    The solution posted above did not help. I had already unlocked it by the time that suggestion was posted.
    I did further research on this site and found that other people had had similar problems. It was suggested to hold down the stop and power buttons at the same time to unlock the feature.
    My unit is back to functioning normally.
  • deeandjer Apr 11, 2008
    my panasonic sa-ht670 says init please wait and nothing else happens. I can't do anything.
I have a panasonic SA-HT720 and it displayed locked anytime i wanted to eject discs so i found out that dad27's solution was the best and holding down the stop and power buttons also locks the system as well as unlocking it. God richly bless u dad27 u really helped me out
Posted on Aug 27, 2007
THIS HELPED A BUNCH!! Thank you so much, this unlocked the trays for us. We wound the "gear" (about and inch and a half in there) till the disc loader was copletely risen - and DVD player has returned from the dead.
message from original poster below \/ \/
"I've just spent the last 3 nights trying to fix that same issue with my sa-ht670 player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
[email protected]"
Posted on Jun 23, 2008
    President:
  • 1,114 Answers
There appears to be a parental lock / password set. If you do not know the password then you can reset it as per the image. Download the manual from link below: http://service.us.panasonic.com/OPERMANPDF/SCHT670.pdf
Posted on Jul 27, 2007
SOURCE:
I had to replug things in for my dish and unit sat sidewards to get to plugs. It now says locked and can eject disc, select source. Help
Try this:
Press and hold [?] (Stop) on the main unit and [>10] on the remote control until "INITIALIZED" disappears from the TV. Turn the unit off and on again.
All settings should return to the default values.
Not saying it will work though!
Not
Dec 31, 2015 | Panasonic...
Multi region code for sa-pt170
hello please help me:
if i press any thing remote for panasonic-sa pt 170
he give me (locked)
i dont know waht i do now
please help me
Dec 16, 2009 | Panasonic Audio Players & Recorders
I cant eject cd/dvd changer.
there may be a lock/unlock selection in the menu somewhere, something like a parental lock on tv sets, this is just a thought on my part.
Mar 25, 2009 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA-HT520 error message
The system has a locked / unlocked toggle sequence on the main unit by holding down stop (or Play) and then tapping the power button. Use this sequence lock or unlock the DVD / CD drawer.
Sep 20, 2008 | Panasonic SC-HT520 System
Panasonic home theatre system 5 cd changer says no play when inserting dvd
Try cleaning the pickup with a cleaner disc-i'm assuming this unit IS supposed to play DVDs, of couse!
Stan
Mar 19, 2008 | Panasonic sa-ht930 Home Theater Audio...
Panasonic home theater
take it apart via the screws on the side and back and then there is a white lever you can pull to unlock it. make sure you are wearing shoes because you dont wanna short the system
Sep 09, 2007 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SC-HT670 System Logo
2,742 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
