Question about Samsung BN59-00599A Remote Control
I have a brand new (3 days old) remote control bn59-00696a for a Samsung LN46A750 TV. It has worked fine until today. I went to turn on TV and no response. I tried to light up remote control with its light on button. Nothing lit up on key pad. I changed batteries and still nothing. What can it be?
  • 2 more comments
  • Anonymous Feb 09, 2009
    BN59-00602A
  • ac6xl Feb 10, 2009
    Red light stays on the TV Mode setting. Nothing works. It won't turn on or turn off the tv, mute or use source. Any suggestions??
    Thanks
  • ac6xl May 11, 2010
    How do you re-code. nothing in manual
  • A Hoffman
    A Hoffman Jun 02, 2016
    Pairing nor recoding.
    President:
  • 1,214 Answers
You may need to recode the remote since you changed batteries, and the newly installed batteries are new, and installed correctly.
Posted on Jan 29, 2009
    Sergeant:
  • Samsung Expert
  • 295 Answers
Use Pairing procedure. If doesn't work after 3 tries, Reset button first.
Posted on Jun 02, 2016
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
We have an AK59-00104R remote for our Blu-Ray player and a Samsung TV. The remote has been working fine on both for over a month now and yesterday it stopped working for the TV. I'm thinking my 1 year old...
To program this Samsung remote to work with a TV, press the TV POWER button on the remote while entering a manufacturer specific code into the remote at the same time.
1. Switch the TV on. 2. Point the remote towards the TV. 3. Press and hold the TV Power button and enter the two-digit code for that brand of TV. If the code is compatible, the TV will switch off. 4. There may be more than one code for that manufacturer, so try them all until one works.
For Samsung TVs, one of the following codes should work: +01 +02 +03 +04 +05 +06 +07 +08 +09
Jan 25, 2011 | Samsung AK59-00104R Remote Control
What is the code for SAMSUNG tv......or how can I manually get the code
Hi! try these steps.. I hope it helps..
1. Turn on the TV.
2. On the remote control, press and hold SET
until the LED blinks twice, then release SET.
NOTE: The remote control will exit programming if
more than 10 seconds elapse between key presses.
3. Enter the first four-digit code for your TV. If
you perform this procedure correctly, the LED
will blink twice.
NOTE: If the LED emits a long blink, the code is
invalid. Repeat steps 2 through 3 and try entering the
same code again.
4. Aim the remote control at your TV and press
POWER once.The TV should turn off. If it does
not respond, repeat steps 2-3, trying each code
for your brand until you find one that works.
The code for samsung tv are:
Samsung 0060, 0030, 0178, 0019, 0056
Jun 10, 2010 | One For All URC-1050 Remote Control
Bose Av38 Media center remote contro issue.
problems of conectivi betwen samsun and bose products many people whit same problem,
Mar 25, 2009 | Bose Lifestyle 38 System
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
I need to find out how to program my samsung RS-105N remote control.
The picture you have is a Directv universal remote.If that is correct.
Turn your Tv on.
Press and hold the TV and SET button until the TV button lights up. 4 seconds or so.
Release the buttons.enter one of the 3 codes below.If the TV turns Off you have the right code,press the TV button to lock the code in.repeat if the code does not turn the TV off
for Panasonic the codes are 034 or 080,056, 164
Nov 01, 2007 | Samsung RS105N Remote Control
Samsung BN59-00599A Remote Control Logo
1,299 people viewed this question
Henry  Thomas
Henry Thomas
