I read somewhere that sometimes the capacitors are the problem, my question, HOW I can open the monitor to check it. I found 3 screws at the bottom, but something is holding the cover...
thanks for your help
Mag Innovision 19 In Wide Lcd Flat Monitor
model LT1919WDb
I checked my computer with other monitor and it worked OK
You shouldnt have to break the clips. my boyfriend got to that point and found that he could slide the plastic off without breaking them
It is not easy. I slip a knife in the bottom edge and slowly work my way around the bottom opening it a little by little. Once you get the bottom and part of each side you can push the plastic towards the top and it will pop off. There are plastic clips holding the bezel down. I always break a couple on opening, but at least the monitor gets fixed. This is not made to open, so good luck.
