Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
No pic .. leds blinks in sequence
Was watching it, it shut down .. when I tried to turn it on, the leds bl/rd/rd came on for a couple seconds then the leds started doing a marque type scan bl-red-red like one of those road contruction arrow sign to move to different lane, then after about 3 mins, it totally shuts off (with just the red led on) no screen ever came on. can't say anything about the sound, cause at the time I had the sound turned down, and haven't be able to turn it up (no screen to see if it even sees it) to check that. Thanks.
  • 3 more comments
  • TWMENT1 Nov 25, 2007
    I've tried to turn our tv on several times. The leds will flash bl,rd,rd and keep on for about 3 minutes and then totally shut off. There is no picture or sound and when we turned it off there was sound... When the tv finally shuts off after the 3 minutes, the 'lamp' light remains on and solid...What's the problem and how can I fix it?
  • Anonymous Apr 06, 2008
    try to power on 3 lights on for 2 min then they blinc 3 min then tv shuts off no pic no sound 3rd led stays lit red
  • alanarcher Dec 12, 2008
    I had the exact same situation. After I watch it cycle through the blinking lights the red "lamp' led stays on for a few minutes before shutting down.
    My TV is 5 exactly years old today. I bought it from Circuit City with an extended warranty. Approximately 1 year ago the main component (I was told that it was the most expensive part on the TV) was replaced. What is my solution and I want it to be covered under warranty with the issues I have been through? It seems that this is also a common problem with this TV.
    Please help
    Alan 602-312-3336.
    12-12-08
  • Joe Jezewski Dec 19, 2008
    Troy..couldn't it simply be that the LAMP has gone out? I haven't read anything in the manuals about a "POWER SUPPLY REGULATOR 1901" thing-a-magig! These other folks' symptons sound JUST LIKE the "LAMP NEEDS REPLACING" SOLUTION, don't you have to agree? My screen has really grown dark===it's ESP. hard to see in the morning hours. I thought it musta been the earth's FALL seasonal rotation, bringing more A.M. ambient sunlitght into my Grand Room...sooo-I got DARKER Window Blinds to put behind the shears on my EAST-FACING French Doors...NAAAH ! That was just hopeful thinking on my behalf! haha
    Joe / Alabama
  • jfk0 Dec 22, 2008
    same problem
    Genius:
  • 1,153 Answers
Intermittent won't start, power supply LED's may be intermittent Cause: Power supply regulator I901 P/N CZ00868 is leaky, may verify the problem by freezing I901.
Posted on Sep 25, 2007
SOURCE:
Push power button and it stays on for a couple seconds and then shuts back off. No picture comes on. Thank you Jeanette
To determine what your problem is:
UNPLUG TV ANDTHEN PLUG BACK IN---TURNON---GREEN POWER LIGHT COMES ON FOR A MOMENT ANDGOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know
SDTECH
Jul 29, 2011 | Mitsubishi WS-65819 TV
Rca HD61LPW42 -- we just replaced the color wheel. now we get a picture but only for a few seconds. then it turns off and after a few seconds restarts. this goes on indefinitely. a couple of times...
Hello
If the power light blinks slowly,
you've tried to turn on the TV during
the lamp cooldown cycle. Wait
approximately 30 seconds, and the TV
will turn on automatically.
If light blinks, pauses for about a
minute, and blinks again: the lamp is
trying to turn on (TV will turn on
when successful). If TV doesn't turn
on and sequence continues, the lamp also
needs to be replaced.
To order lamp call 1-800-338-0376.
Have your TV serial number
and lamp type available (you'll
find this information on the
sticker that's on the right side of
the TV).
OK.
Jul 24, 2011 | Televison & Video
Power button goes on for a few seconds when clicked and then turns off before picture comes on.
When it shuts down press the menu and Input buttons on the set both in together and hold for 6 seconds the led will then start to blink a two digit blink code which will repeat a few times indicating where the problem is. Let me know the blink code sequence and I will assist you with the problem.
Jun 11, 2011 | Mitsubishi WS-55809 55" Rear Projection...
When I turn the tv on the power light goes green for a couple of seconds then it shuts off and the picture never comes up.
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
Jun 03, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Turns on for a couple seconds and immediately turns itself off.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
Let me know what you find and I will tell you what I know.
SD TECH
May 10, 2010 | Mitsubishi WT-42313 42" Rear Projection...
In my WS 65809 projector tv, when I turn on the power, the green light clicks on for a couple of seconds, then clicks right back off.
DO THIS AND LET ME KNOW WHAT YOU FIND:
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I was watching it and it just shut off when i turn it on 3 seconds later it shuts off again
this set has a self diagnostic feature:
If this has been helpful I would appreciate a vote from you here; if you need direct help:
etower.766@netzero.net
Aug 14, 2009 | Mitsubishi WS-65809 65" Rear Projection...
2001 Mitsubishi 65 inch HD1080 rear projection. When I turn it on, green light comes on for 2 seconds then it turns itself off. No flashing green light like others I read about.
Ok, try this first. After attempting to turn on set after it shuts off push and hold the MENU and INPUT buttons at the same time on the front of the set for 10 seconds. This should acccuate the self diagnostics function in the micro and the power LED should start blinking a two sequence code. That code will narrow things down.
Jun 03, 2009 | Mitsubishi WS-65511 65" Rear Projection...
No Picture, The power and the OPC Led's are blinking
Your TV is in fault protection. Due to blows caps on the PSB-power supply board.
Best Regards and Semper Fi
Mar 27, 2009 | LCDDigital LCD7 Television
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
