Question about Denon AVR-1802 Receiver
Denon AVR 1909 - tuner audio intermittent - off and on repeatedly
I have a Denon AVR 1909 - all seems to work well except for the radio signal - when set on tuner the audio signal comes and goes intermittently (on again, off again, repeatedly). Any help????
  • 1 more comment
  • donnanalley Jan 29, 2009
    yes - the antenna is connected, and when the audio is received, the sound is nice an clear.....it just comes and goes
  • intersys Jan 30, 2009
    I have the same thing happening......I have a Denon AVR-889. Audio on the tuner is intermittent. I have TV and Vblu-ray connected via HDMI.
    I discovered that if the TV is on before I try the tuner - sound is fine. Even if I turn off the TV the sound remains fine.
    If I turn the tuner on first and no TV - audio is intermittent. I'm guessing that there's some kind of HDMI prolem - even though the tuner function has nothing to do with HDMI
  • donnanalley Feb 03, 2009
    Wow - it works for me too! Very strange - I have a TV connected with HDMI, and a DVD connected with HDMI. I have no idea why that would impact the turner audio - but apparently it does. Wonder how many other people are having the same problem?
    THANKS a TON! I will just have to remember to turn my TV on first when I want to listen to my favorite radio stations.....
I have the same issue, and i believe it may be an issue with setting the audio input source to 'auto'. the radio may be stuttering because the receiver is changing from different audio modes such as 'dolby digital' to '5ch stereo' (for example) when it detects a change in the radio signal
Posted on Jan 04, 2011
  • 119 Answers
Make sure you have an anteena connected and adjusted
Posted on Feb 25, 2009
I can't seem to get the tuner to work on my Denon AVR 2803 receiver.
It can't hurt.
You will lose all your settings though. So you'll have to set the amp up again from scratch.
Before you do initialise, let's just check.... You plugged in a FM or AM aerial, right?
Sep 13, 2014 | Denon AVR-2803 Receiver
Denon avr-1909 has sound but no video, tried everything!!
Denon requires that you assign video to specific ports. HDMI, RCA or any other- you have to select which type and which port and you will get video.
Oct 22, 2013 | Denon AVR-1909 Receiver
Setup help for record player (Pro-Ject Carbon Debut) and pre-amp (ART DJPRE II) into Denon AVR-1909. I have everything setup properly, but I cannot get the subwoofer to turn on with my 2-channel settings...
In two channel mode, there will be no subwoofer signal unless you change the front speakers to 'small'. If you set the front speakers as 'large' then the full frequency spectrum will be sent to the front speakers, and none to the sub. Switching from bluray may keep the surround configuration until you restart as you mentioned.
Sep 26, 2013 | Denon AVR-1909 Receiver
I have a denon receiver avr 1909 and the remote control volume button do not work. A new remote control for this receiver is available?
If you mean a replacement, then I would contact Denon they should be able to tell you where and who can supply one. Generally replacement remotes are very expensive. So you might want to consider a universal one.
Aug 04, 2013 | Denon AVR-1909 Receiver
WHATS THE MOST COMMON AND SIMPLIEST SPEAKER CONNECTION FOR THE DENON AVR 1909
Hello,the simplest and most durable is the banana plug,while the most common is simply connecting bare wire.
Feb 21, 2011 | Denon AVR-1909 Receiver
I need reset DENON RC-1099 in begin state
Entering a new remote code will automatically erase the existing code for the device it is currently operating.
The remote for Denon devices is 111.
http://www.usa.denon.com/AVR-1909-OM_E_004.pdf
Dec 13, 2009 | Denon AVR-1909 Receiver
Tuner not working.
These do on occasion have a bad fm tuner assembly. part number 9630145608. to verify try a fm ant to see if works
Dec 09, 2009 | Denon AVR-1908
Denon AVR 1910 - no sound from v-aux or tuner
The tuner is the best source for testing audio issues from a receiver since it uses an internal source for audio. This problem could be two separate issues. Check the tuning in the tuner to make sure it is on a station that you are receiving. The newer Denons will not play any audio is the station is not coming in. Be sure your antenna is connected and tune the station to one that comes in clear.
What source is hooked up to the V. Aux? If an iPod it is common that the volume on the ipod is down .
Nov 22, 2009 | Audio Players & Recorders
Intermittent Audio when set on "tuner"
You may have to ( first unplug it from the wall) then pull the top case.
Locate the tuner board , it will be the one with the antenna connections sticking out the rear of the rec'r.
If there's some way to pull the circuit board up and out of a socket/sockets , try that and re-install it.
Other than that I may be able to help you find a good tech.
Jan 15, 2009 | Denon AVR-1905 Receiver
Denon AVR-1802 Receiver Logo
707 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
