Question about Reddy R115DT Oil Filled Utility Heater
Motor Running backwards.
I can get it to run properly by turning the motor the proper direction when starting but as soon as it stops then starts on its own it runs backward and shuts off immediatly.
  • Anonymous Mar 03, 2009
    Problem Solver:
  • 5 Answers
Flip ur wires on motors. just reverse ur polarity.
Posted on Jan 07, 2010
My bosch 4100 lost power and the blade started running backwards. what went wrong and what parts do I need to order to fix it?
for an electric motor to run backwards it requires a current direction change in the fields
as that is not possible unless there is a direction change switch as in a reversible drill there is a major fault in the motor windings
take it in to an appliance repair shop for a proper diagnosis and quote
Dec 01, 2016 | Bosch Saws
I have a Zebra 170xiIII. The feed motor runs both forward and backward. Will be running fine and I have to pause and will start running backward. Have replaced motor and same thing. What's wrong?
The DC power supply drives that motor and may start running it backwards when it begins to fail. The motor normally makes more noise than usual in both directions when it starts to fail like this.
Google "43470-002 power supply, Xi III +" and you will be able to purchase the part.
Feb 24, 2015 | Zebra 170XiIIIPlus Thermal Label Printer
Rear motored truck on kato ho p42 after dcc installation not working properly after period of time
I've had the same issue. I doubt it's your DCC hookup. Those motors are probably shot, and need to be replaced. I run analog, and I've had multiple motor failures with these things. These motors don't last long and, when one goes, the other one often follows... fairly soon after. I was able to prolong the motor life a little bit by orienting the motors to run the same direction. (I turned the rear truck around. I realize that's probably not possible, with your DCC in place.) I've still had motors fail, in spite of motor orientation. I've got all nine units, and six of the nine have had to have motors replaced. Some units, I've had to replace motors more than once! I haven't figured out any way to bring a motor back to life, once it starts stalling intermittently, or if it quits altogether. Sometimes, rotating the motor a tiny bit in its cradle might help, but that's a stop-gap. I suspect motor failure... unrelated to the DCC hookup.
Feb 04, 2014 | Kato HO P42 Genesis AMT PhVb 161
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
Well, lets see - posted problem with spinning wrong direction - had one free answer to problem - looks like I got my money's worth - It's the wind - of course - why didn't I think of...
If its a twin fan model a/c, sometimes what can happen is one of the fans is dead or not starting properly due to a failed start capacitor or the motor may be open circuit. The other fan when running creates a "vacuum" which sucks the air through the bottom ( or the other fan) which causes it to "run backwards" The suggestion from what was posted earlier ,of the wind causing it to run backwards is also possible if the start capacitor (or motor) is faulty. if the motor doesnt have the power to start up in the correct direction and the outside wind is strong enough, the fan motor can actually be "blown backwards" Hope this helps,
Jul 16, 2011 | Heating & Cooling
Model WJSE4150B2WW ser# AF171808G GE washer agitates but won't spin with front cover off motor turns belt in the right direction for just an instant and then stops interior basket can be turned...
When spinning the motor freezes up and will not spin. I released the motor and took off the belt off and the motor ran fine. However the pulley that the belt is also on will not spin the proper direction, only backwards.
Mar 03, 2011 | GE WJSE4150B Top Load Washer
Hayward Super ll Pump - shaft spins opposite direction when it is running, what can cause this?
The only way a motor for these units can run backwards is if the internal lead connections of the winding are reversed. On some rare occasions I have seen a failed start cap cause a motor to start in reverse but turning it off and on would fix that. If your start cap checks out OK and the motor is truly running 'backwards' you will need to replace it.
If on the other hand the flow is not going the correct way look into the valves and filter(s) for issues.
Jan 22, 2011 | Hayward 1HP Super Pump II Inground Pool...
Condenser fan running backwards on heat pump
I am having the same problem, sometimes it runs in the wrong direction, blowing the air down. Sometimes something gets tripped and I need to turn the thermostat to off and wait a bit then restart it. If I am lucky it will run int the correct direction and also will warm the house. Sometimes it send nothing but cold air to the house's forced air.
Jun 13, 2009 | Goodman CKL24AR24 Air Conditioner
Hobart A-200 Motor Direction
No, do not swap hot and N.
First, verify rotation. As the attachment shaft rotates, it should push the engagement pin into the keeper slot. Looking down on top of the mixer, the planetary should rotate clockwise.
If the unit runs backwards, does it start slow? Can you get it to run either way by giving it a push start before turning on the power? If so, your start switch is not working properly. (Which is my guess) Check your capacitor.
There is mechanical and electronic start switches. (Metal arms and a contact or a little gold rectangular metal can.)
Check it out and let me know what you find -- Mike
May 19, 2008 | Hobart A200 Stand Mixer
Reddy R115DT Oil Filled Utility Heater Logo
128 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
