Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA won't come in
Our RCA 52 inch when turned on with remote/or on the unit, lights (green light on tv) up three times and then stops. TV won't come on. Any ideas? Is it costly to repair?
  • Anonymous Feb 18, 2009
    the power switch blinking on & off the tv won't come on
  • Anonymous Feb 19, 2009
    same here
I had this exact problem with one exception for about two months. I kept pushing the on/off button manually. TV stayed on after about 10 trys. This is how I turned my set on each day. This set didn't
cost that much, and anything over $100.00 to repair it is stupid.
My solution
I had my set plugged into a circuit protector bar. I just now unplugged my set and plugged
it in to the back side of my cable box. I then pushed the on/off button on the set severl times
with the cable box on, till the tv came on. The tv now comes on every time I turn on the cable
box. No repair needed. Just a bad on/off switch, but why replace it. Rick
Posted on Feb 17, 2009
This was happening to us also~We found a solution with help from this site. We replace the CP150 capacitor which was bad. We replaced it with a 25v (it is normaly only a 16v 2200 uf). It helped but was not the whole problem. We also had a cold soder joint on a capacitor in the main power supply (the board with the two large capacitors and two transformers, they are tucked far back). This is the borad where the ac cord is connected. Hope this helps.
GOOD LUCK!!!
Posted on Feb 18, 2009
  • chrisnkaliss Feb 18, 2009
    HERE IS THE LINK THAT HELPED US WITH PART OF THE PROBLEM (replacing the CP150 capacitor)~(THANKS CHAD_FEASTER!!!)
    Just fixed it!!! Remove the back panel from the television, you will see a board where the input jacks are located. To the left you will notice a red power wire. Just up and to the right approx 7" or so you will see a [_] shaped metal shield surrounding a capacitor in the middle of it. The part # on the board is CP150. It is a green/gold 16v 2200uF capacitor. More than likely this capacitor is faulty. Run your finger over the top of the capacitor, if it is beveled rather than smooth you have a definite solution to your problem. You may need to remove the plastic piece that covers the transformer to the left of the capacitor to gain easy access. Good luck!!
52 Inch RCA TV Model HD52W55 does not turn on green power light blinks 3 times but does not turn on. ive got it to turn on once before, and left it on since, accidently shut it off and cant get it back on,...
The best assumption, at this point, is that the power supply board has died. You can buy a replacement unit from the link below and have it professionally installed.
Power Supply
Aug 28, 2011 | RCA HD52W58 52" TV
I have a 52" GE-HDTV/Monitor. After the unit is turned off, it will not come back on-at all now. When I try to turn it on, the green light on the front of the TV comes on briefly, then goes off. I can...
replace CP150 CP114 and CP120 all three capacitors are available at the following link with free instructions they are listed under the RCA parts category which are the same ones for your GE TV.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
1995 rca 52 inch tv...
Please post the model number of your RCA as usually its a bad flyback and start up capacitor when you get a 3 blink error code . But I can help you better if I have the model number of your set.
Oct 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on
my tv wont turn on and i dont have no sound or no picture it flask on and off
Feb 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca d52w20 52inch tv doesn't want to turn on
Well not knowing this particular unit myself, i would strongly suggest troubleshooting the users manual, which can be downloaded here.
http://tv.rca.com/en-US/UGConfirm.html?modelno=D52W20
Jan 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
283 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
