Question about Epson Expression 836XL Flatbed Scanner
Expression 836XL scanner
Scanner will not work when using the paralell port(LPT1). running XP pro SP2 and it does not see the scanner
    Problem Solver:
  • 6 Answers
What make and model is the scanner and do you have the driver for the scanner installed.
Posted on Jul 27, 2007
Fuzzy scanned image from Epson Expression 10000XL scanner
Make sure that the item being scanned is lying flat against the scanner's glass. If the scanned image is still fuzzy after adjusting the object, clean the scanner glass with a lint-free cloth and some vinegar or ammonia-free window cleaner.
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Apr 10, 2010 | Epson Scanner Expression 10000xl Pro A3+...
Scanner stopped working in mid scan. Now freezes when asked to preview or scan.
reinstall the driver... if that does not work then your scanner is broken and needs to be looked at by a service technician...
Dec 23, 2009 | Epson Expression 836XL Flatbed Scanner
Cable connectivity with my laptop through a "parallel to usb cable". My laptop has no parallel port but only usb ports.
make sure you follow this step :
1. install driver USB to Paralel port (LPT1) before the cable connected to PC
2. After the driver installed, install the cable - and it supposed to be detected
3. the last think u have to do is install the scanner/printer driver
if it is not work, i guess the problem is on the USB to paralel adapter, or the driver not installed correctly
Jun 01, 2009 | Acer ScanPrisa 640P Flatbed Scanner
I need the drivers scanner color page vivid pro II film
I lost my scanner driver CD. Can I download free scanner driver for genius colorpage vivid pro now? How?
Apr 18, 2009 | Genius ColorPage Vivid Pro II Film Flatbed...
Our Epson Scanners do not work from Photoshop CS4
Try using a separate scanner utility to do yr scans - not ideal but sorted my problem. I use the EPSOM scan utility with a Perfection 2400 scanner.
Apr 17, 2009 | Epson Expression 1640XL Pro Flatbed...
Canon bjc 50 printer
You are correct on your deduction.
It is the USB to Parrallel adpter. They are not reliable in the XP/Vista enviroment. I have run into this several times.
Oct 07, 2008 | Canon Office Equipment & Supplies
Printer error message when tried to print test page
You are going to need SP2 to run many applications, doing system restore to before SP2 setup will make SP2 unusable.
If you can install, the printer on a different plug. Uninstall and re-install drivers as suggested on other post, afterward connect printer to new port, drivers will work differently.
You can also try this:
Disconnect printer.
Remove drivers
Uninstall sp2
restart pc
re install SP2
Download and install latest drivers
connect printer
In this way there are less chanches for driver interfeering with sp2. Use last driver version, older drivers may not work well on sp2.
If this had been helpful vote my solution in the other thread. Thanks
Apr 15, 2008 | Office Equipment & Supplies
Connecting my HP ScanJet 5200C scanner to my HP Pavilion Home pc
Rookssailor,
I don't think you can (successfully) run this scanner off the paralell port. I'm drawing on memory here but I think this scanner has serial and usb ports. If you are running Windows XP, use the USB hookup. If you are running Windows 95, 98, Milliniaum then you might want to use the serial port. At any rate the scanner software should be installed before you plugin the scanner.
If I'm completely "full of it" and you really want to use a Paralell connection then you might want to use a paralell to USB adaptor (Belkin, perhaps others make one of these).
haMAR
Apr 01, 2008 | Office Equipment & Supplies
Fujitsu 5210c Scanner
Uninstall the scanner software and also the program you use to access the scanner Restart the computer and reload the software[s] Or first try a system restore.
Jun 25, 2007 | Fujitsu ScanPartner fi-5120C Pass-Through...
Epson Expression 836XL Flatbed Scanner Logo
143 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
