Question about Radio Shack Pro-94 Scanner
Pro-94 will not recieve
Hello all, I have a Pro-94 1000 channel scanner and it will not receive any freqs, no NOAA stations either. I have tried a new antenna, but had no luck with that. The local police freqs will come in but not clear enough to listen to. Any ideas anyone? Help Please
  • 3,018 Answers
  • Make sure the frequencies are put in correct. Another thing to remember is that scanners receive from repeaters the police, FD, etc use. Make sure you are in range. Sometimes an external antenna is necessary if this is the case. Another thing to note is that many police districts are switching to a digital system that some analog trunking scanners will not be able to receive. If someone wants updated frequencies in the area I can provide them (USA only sorry).
  • Hope this helps.
Regards,Tony
Posted on Oct 28, 2011
  • 127 Answers
I would make sure you have
the new frequency # put in scanner
GOOGLE free new scanner frequency #
put in your town and city.
Posted on Jun 20, 2009
Can't seem to get any activity even after programming some frequencies in to it(BC72XLT)
Are you sure that the frequencies you programmed are active in your area? Try a weather band search (press Func and Svc) to verify that the scanner is working properly. If you receive one or more NOAA weather broadcast channels then you need to visit www.RadioReference.com and check their database for active freqs in your area. If you cannot receive weather then you have an antenna or receiver problem.
Bill B.
Listening in since the 60's
Oct 14, 2010 | Uniden BC72XLT Handheld Scanner
MY RADIOSHACK NASCAR PRO-84 SCANS THREW CHANNELS BUT STAYS STUCK ON ONE CERTAIN WEATHER CHANNEL AND WONT CONTINUE SCANNING AND I NEED TO NO HOW TO DELETE THAT CHANNEL COMPLETELY.
The NOAA weather frequencies have constant broadcasts, so your scanner "locks" onto them. The only ways to prevent this are to either delete the weather frequency or lock it out. To delete, just program the frequency "0.0" (zero point zero) into the channel. To lock it out, press the L/O key while on the weather freq.
Bill B
Aug 06, 2010 | Radio Shack Pro-84 Handheld Scanner
Scanner not picking up local police-Fire freq
Do you still receive NOAA weather frequencies? Sounds like your local agencies have switched from simplex/standard frequency operation to trunking. I suggest you visit www.RadioReference.com to view the latest on active frequencies and systems in your area.
Bill B
May 17, 2010 | Radio Shack Pro-94 Scanner
Problem with PRO-2066 scanner not receiving local 800mhz Motorola trunk system II. It does trunk with the current data channels used (showing the ---- line) but I only hear transmissions on freqs ending...
It is difficult to explain in simple terms but I will try.
Google rebanding.
Some radios can have their firmware updated but I don't think your PRO 2066 can.
Channel numbers and frequencies preprogrammed into your scanner have changed over the past few years.
When a data signal says go to channel X that channel is now Y, but your scanner is still looking for X
Hope this helps
Aug 21, 2017 | Radio Shack Pro-97 Handheld Scanner
Pro95 shows trunked freqs are being received, but no audio...
be foe you can recieve them in a closed mode you must input their talkgroup id if not you will not recieve anythang also remember to set your mode to Mot for motorola, fm is foe conventional, am is for aircraft...ect. in the oppen mode you will pick up everthing and their neighbor that uses the frequency set. hope this helps
Jun 01, 2009 | Radio Shack Pro-95 Handheld Scanner
Need to unlock our radioshack pro 2018 200 channel desktop scanner
Easy to use right out of the box!
Explore preset frequencies used for non-trunked police/fire, aircraft, marine, NOAA weather and more. Just attach the antenna, switch it on and touch one of five buttons. With just two keystrokes, you can store a frequency you find in the 200-channel memory for later scanning or monitoring. You can also search for activity in frequency ranges you specify or program known "action" frequencies on the keyboard.
  • 1-touch search lets you find police/fire, HAM radio, marine and 7 NOAA WX frequencies fast
  • Built-in weather receiver sounds an alarm when your NOAA weather station sends an alert
  • 50-frequency search skip locks out undesired frequencies
  • Programmable by computer (requires Scanner PC Programming Kit #20-048)
Aug 06, 2008 | Computers & Internet
Pro-97 scanner recieving problem
try going to a urban area and scanning the NOAA band. if that works your programming is wrong and there is nothing wrong with your AM/FM base band. also the BNC antenna connector on the inside is notorious for breaking away from the board, nothing a little solder cant handle. Also make sure your local freq's are not Digital
Dec 05, 2007 | Radio Shack Pro-97 Handheld Scanner
162.550 NOAA weather frequency
If your still having the problem, it could be that the transmitter for that freq lost some of it's power, so your scanner cannot pick up a clear signal. If everything else is working ok, that's my guess. Hope this helps,,, Mechanic
Nov 15, 2007 | Radio Shack Pro-94 Scanner
1000 scanner radio shack
press the manual button a few times, and make sure there are actually some freq. programmed into the unit. if there are freq other than 000.000000 in there, press the s/s (lockout) button and see if this unlocks the frequencies to allow them to be scanned.
Aug 19, 2007 | Radio Shack Pro-94 Scanner
My 95 is way off - Freqs,Mode not working...Grrr!
mORE AND MORE POLICE AGENCIES ARE SWITCHING TO "DIGITAL TRUNKING". I CAN ONLY PICK UP PARTS OF MY LOCAL SHERIFFS STATIONS. RADIO SHACK HAS THE NEW dIGITAL TRUNKING SYSTEMS THEY COST ABOUT $500. I AM UP GRADING NOW. FOR TRUNKING ... WHEN YOU GET A ACTIVE CHANNELL KEEP HITTING THE RED TRUNK BUTTON TILL YOU SEE THE MOTOREOLA 5 NUMBEWR ID.THJEN HIT ENTER. I WANT THE NEW PROGRAMER THAT IS FAST ENOUGH TO FOLLOW DIGITAL HYPER-TRUNKING. ALL POLISE ARE GOING TO IT EVENTUALLY.
Sep 18, 2006 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-94 Scanner Logo
197 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
