Question about Estate TAWX700JQ Top Load Washer
Don't run all the way thru
Our estate washing machine stops filling then if you open the lid and shut it a few times it'll start back up then stops again now it won't go at all
  • 5,911 Answers
This problem is commonly attributed to a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured.
If you determine that your lid switch is broken, the following link will give you the necessary steps to replace it: http://www.fixya.com/support/r397101-replacing_lid_switch You can order a replacement switch on line at searspartsdirect.com. Just type in your model number and look for item 9 under the "Top and Cabinet" heading. The lid strike is listed as item 20. NOTE: Another thing that can cause lid switch malfunctions, is the lid being bowed. This can occur from placing heavy items (such as detergent bottles and clothes baskets) on top of the washer. If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Posted on Jan 29, 2009
I have a top loader washing machine with a filling problem. don't think its hoses or valves I think its electrical in the control panel. after the machine filled, I opened the lid to switch the water
most washers will stop what ever there doing (filling) if you open the lid this is a std safety feature . and sometimes this same switch malfunctions and gives a false indication of a door open
Feb 10, 2015 | Kenmore Washing Machines
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Will not wash or spin
the two most common things are a broken lid switch or motor coupling,if you can hear the motor running but nothing else is happening you have a broken motor coupling,if it filled with water and then nothing check the lid switch,close the lid and then open it a few inches,open and close it like this a few times,if you don't hear a clicking sound when the lid opens and closes then the lid switch is bad.next time send the model number off of the washer,it will start with 110. or similar. http://www.youtube.com/watch?v=MFsvLiuTniU this will help you with the lid switch but the part number could be wrong,when you call your parts store give them the model number and you'll find it right under the bottom of the lid when it's open.http://www.youtube.com/watch?v=9K1KHEogf3c copy and paste for the motor coupling,good lick and hope this helps
Oct 15, 2011 | Kenmore 24032\24036 Top Load Washer
Why does my toploader washing machine just shut down as though it is not getting electric current
does it fill with water and then nothing?if so it sounds like the lid switch is broke,open and close the lid a few times,open it a few inches and close it,if you don't hear a clicking sound the lid switch is bad.and it will be like the washer is dead after it fills
May 15, 2011 | Kenmore 14102 Top Load Washer
Our washer is filling with water but will not run the cycle after it fills. We were able open and close the lid and it would start but now it only fills with water...Please help!!!
the lid switch is buggered the lid can be open while its filling but when it goes to start washing the lid needs to be shut so the lid switch isnt working so the machine thinks the lids open.
Jan 05, 2011 | Maytag Washing Machines
Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine timer stops mid cycle
Your lid switch needs replacing.
Part number 3949237 available at any applinace parts store.
Apr 05, 2009 | Estate TAWS800JQ Top Load Washer
Top Load Whirlpool washing Machine
Still can have a bad lid switch/ check the plug in connector to the lid switch
Jan 16, 2008 | Tecnik TKL9260 Front Load Washer
Estate TAWX700JQ Top Load Washer Logo
48 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
