Question about Dell Dimension 3000 PC Desktop
Need to reboot my dell/windowsXP hard drive to factory settings
  • 382 Answers
You should be able to go to restore and restore it to the original settings. If it was not enabled then you would have to use the original restore disks you recieved when you bought the system.
Posted on Jan 29, 2009
    Scholar:
  • 140 Answers
You have to put in the cd that came with your dell, then boot your computer. It will boot from the cd and give you an option to restore your factory condition. It will take around 1-2 hours for the process to complete.
Reset dell celeron pc to factory settings
To do this you will need the restore cd or os cd that came with it. Put it in the pc and reboot. Press f12 on dell splash screen and choose boot from cd. Just follow the prompts from there. If you do jot have any cds you can use any cd that has identical os on it to restore to factory except you will jot get dell software that comes from factory. Also keep in mind that any of these steps will delete all data from your hard drive so make sure it is backed up.
Jun 03, 2014 | Dell Inspiron 1501 Notebook
Cannot reset my Dell desktop to its factory settings
Check Dell website to find out if you still have the factory operational system.
Feb 03, 2013 | Dell Computers & Internet
How to reset settings
A persistent operating system error on your Dell Inspiron 1525 laptop requires more than just a system restore as there is a problem with a driver that a system restore cannot correct.
A full factory reset of the laptop wipes the hard drive clear of all data including existing driver settings and programs and installs the original operating system back to the hard drive.
Once cleared, previous computer files and programs are non-recoverable.
Press "Power" on the Inspiron 1525, and continuously press "F8" on the keyboard when the Dell logo appears on the laptop's screen.
Press the down arrow to highlight "Repair Your Computer," and press "Enter" to select the highlighted onscreen option.
Click your preferred keyboard layout, and click "Next" to continue with the laptop's restoration process.
Type "administrator" in the username field, click "OK" and click "Dell Factory Tools."
Click "Dell Factory Image Restore," and click "Next." Click the checkbox next to the hard drive reformat confirmation, and click "Next."
Click "Finish" to reboot the OS after the restore process finishes, which can take up to 10 minutes.
Hope this helps.
Nov 12, 2012 | Dell Inspiron 1525 Laptop Jet Black
Sata Hard drive errors and Raid errors
See this answer
Reboot your system and hit F2 as soon as you see the Dell startup screen (the options are F2 for setup, F12 for boot sequence).
In the System Setup screen, do these steps.
Select Drives:
Make sure your Diskette Drive (3.5 floppy) is set properly (Usually set to Internal)
Make sure that "Drive 0: SATA-0" drive is set to "ON"
Go to "SATA Operation":
Your system proabaly came set to "RAID Autodetect / AHCI" - THIS SETTING CAUSES YOUR SYSTEM TO GO INTO AN IDE LOOP AND DOESN'T ALLOW IT TO FIND YOUR FACTORY INSTALLED SATA DRIVE.
CHANGE THE SATA OPERATION SETTING TO "COMBINATION"
Reboot - make sure that the boot sequence is set to CD rom before HD and make sure that the reinstall CD is in the drive. Setup will load, hit enter to reinstall XP. Your HD should now be detected and you should see the licensing agreement.
If you have your files backed up I reccommend deleting the partition and reformatting prior to installing XP, it will give you that option after the license agreement.
Once you have successfully reinstalled the OS, Dell reccommends that you change the SATA Operation setting back to RAID AUTODETECT / AHCI (or back to whatever your factory setting was) to avoid any problems with other IDE devices installed on your system.
Source
Restore Complete but Stuck on DRMK
Sep 03, 2012 | Dell Dimension 9150 (DIM915MIN) PC Desktop
What solution because dell notebook blank display after reboot
If the Dell logo comes up on the screen and goes to blank display, the problem is in the hard drive or windows files have been corrupted, remove the hardware and reseat it back in place, sometimes this will restart it, if no change! reload your operational system with the disc if available to factory setting. If none of these work the hard drive needs to be assessed for replacement.
Mar 23, 2012 | Dell Inspiron 6000 Notebook
My Dell Dimension 5100 desktop wont boot up, it starts the DELL sequence but then messages with F1 reboot or F2 setup Utility. I have recently had to revert my pc back to factory settings and restore...
thegreensx4
It does sound there is a problem with the hard drive. However if you hit F12 at boot you will get an option to run the system diag on the computer. Let me know the error you get and I can tell you where the problem is.
Issken
http://www.fixya.com/users/issken
Jan 13, 2011 | Dell Dimension 4300 PC Desktop
Dell D610 will not boot to hard disc
in os installed not corrected driver (s).
1. when goin bott press F8 and select "Dont reboot when error..."
windows go in blue screen, and write to screen what still by error (file name)
2. Try boot in safe mode. Find and delete this file.
3. Boot in normal mode.
If dont work. Boot with help WinPE bootdisk and scan your system by Viruses and Malware
Nov 07, 2009 | Dell Latitude D610 Notebook
Reset to factory settings
Get your Recovery CD, and just completely reformat the hard drive, These discs should guide you threw this. If you do not have the Recovery CD's Then you may have to order them from Dell.
Nov 25, 2008 | Dell Dimension 3000 PC Desktop
DELL C400 LAPTOP
you may need a separate hard drive, you could try to boot off of that
Oct 24, 2008 | Dell Latitude C400 Notebook
Dell Dimension 3000 PC Desktop Logo
251 people viewed this question
Alun Cox
