Question about Lexmark JetPrinter Z25 InkJet Color Printer
Printer problems when I turn on the printer the cartridges shoot violently from on side of the printer to the other side.On turning the machine off the cartridges again flies violently to the side and stops with a thud. The same symptoms are experienced on attempting to print. A vocal message from the computer tells me there is a problem with the printer, and the 2 green lights on the top of the machine flash on and off. Also when lifting the front cover the cartridges slide from right to left at high speed, past the point where it should stop to allow for an ink cartridge change. I have reinstalled the driver cd supplied with to printer and the fault still remains. thanks to anyone who may be able to help, Tony H
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 58 Answers
Two areas to check: (1) There's a encoder strip (sliver colored metal in the lexmark) the sits right behind the carriage assembly (where the cartridges are installed). It is slotted with "timing marks". This lets the machine know where the carriage assembly is at when parked in home position or starting to print a job. You can carefully clean this with water and a paper towel or cotton swab. I would recommend using some canned air to clean it after that since some of the paper fibers for the towel could be left behind. (2) The carriage rod that the carriage assembly (see above) rides on gets dirty and dry. Clean it with some water and paper towel then use a drop of light weight oil (3 in 1 or sewing machine oil) on it one either side of the carriage assembly. If these don't work, probably time for a new machine.
Posted on Jul 29, 2007
My printer Lexmark X4270 is displaying on it's screen always Error #1203. what can I do?
error 1203 is cartridge error, cartridges has a short
1. press power button to turn off your printer
2. unplug your printer to the wall outlet
3. plug in your all in one
4. reinstall your cartridges
if this does not resolve the problem replace your cartridges with new one
for more trouble shooting option :
1. click start> program> lexmark 4200 series> lexmark solution center
2. click the trouble shooting tab on the left side of the screen
i hope this helpful
thank you for using fixya
Feb 03, 2011 | Lexmark X4270 All-In-One InkJet Printer
When I turn on my printer it makes a clicking noise, the paper rolls spin but won't take paper, the ink cartridges slide violently back and forth. Is it fixable or should I just get a new printer?
Have you already tried these steps?
The "violently back and forth" of the carriage sounds like it could have additional problems, but I'd try all these steps up to servicing the printer.
Nov 02, 2010 | HP PSC 1210v All-In-One InkJet Printer
Lexmark z617 printer not working, printer cartridges shooting from side to side when poweed on or lid opened & closed
When you say "printer cartridges shooting from side to side when poweed on or lid opened & closed", do you mean that it's banging from side to side? Turn off the printer. Remove the cartridges from the printer. While the cover of the printer is open, check inside for anything out of the ordinary like any tapes or strips that are loose. If none, turn off/on printer and reload the cartridges. If the banging noise is still present, I suggest you contact Lexmark Technical Support to further investigate the problem. It might be a mechanical problem in the printer.
Jul 15, 2010 | Lexmark Z617 InkJet Photo Printer
How to solve error 1200
Try these steps :
Take methylated spirits on the cloth , turn machine off, and open the cover as you would do it when replacing cartridge.
make sure machine is turned off so cartridge will not move to center.
clean the chrome metal bar inside machine with the methylated spirits - move the cartridge to the other side of printer manually. and clean the same bar that the cartridge was sitting on.
this should fix the problem.
If not please reply back for further assistance.
Mar 16, 2010 | Dell 922 All-In-One InkJet Printer
Opened door to check on cartridges and the whole mechanism flew violently to the left side where it appears to now be stuck. Cannot find manual...help! The entire machine jumped when this occurred. Have...
New printer time. Yours is at least 5 years old and inkjets are built to only last 3-4 years. New printers go for about $100. It will cost you at least that much if you can find someone to just llok at your broken one.
Feb 09, 2010 | HP PhotoSmart 7350 InkJet Printer
HP DeskJet 812C Hardware Problem! with Printer cartridge carriage. Printer Cartridge retracted into right side of case will not come out. There is No paper jam in machine to prevent it from doing so. ...
Disconnect the "data" cable (parallel or USB).
Disconnect the "power" cable.
Reconnect the "power" cable.
Turn the printer on.
Lift the printer's lid -- the print-carriage should slide the printer-heads to the "middle" position.
If all else fails, take the printer to a qualified technician, for more trouble-shooting.
Feb 02, 2010 | HP DeskJet 812c InkJet Printer
Problem with faded printing along right side of page - both black and color.
Turn the printer off.
Remove the ink-cartridge(s).
Gently "slosh" it from side to side -- do not "vigorously-shake" it.
This will move some of the toner towards the "right" side.
If this does not help, it's time to take the printer to a qualified technician, for proper trouble-shooting.
Nov 18, 2009 | Dell 3100cn Laser Printer
Lexmark error #1200
make sure machine is turned off so cartridge will not move to centre.
clean the chorme metal bar inside machine with the methylated spirits - move the cartridge to the other side of printer manually. and clean the same bar that the cartridge was sitting on.
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Apr 02, 2009 | Lexmark X4270 All-In-One InkJet Printer
I have an error #1200 on my fax machine it won't clear
Dec 09, 2008 | Lexmark X4250 All-In-One InkJet Printer
Lexmark JetPrinter Z25 InkJet Color Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
