Question about Campbell Hausfeld VH6111 Oil Lubricated 60 Gallon Cast Iron Air Compressor
Compressor hard to start when cold
When it is cold out this conpressors motor kicks on but the belt burns a little until it starts to spin. Can I use a lighter weight oil in the winter time?
    Sergeant:
  • 359 Answers
Sounds more like the pressure relief valve that takes the air pressure off the compressor upon shut down so when it re-starts there is no pressure until the motor gets a start this is known as a unloader valve and is usually a small brass valve that looks like a fitting and will hiss on shutdown,if it sticks the motor trys to start with the load of the air pressure on it and slips the belt due to load
Posted on Jan 30, 2009
Armstrong concept 1200-bad start/run capacitor?
Yes, most likely the start capacitor has failed & should be replaced. You have proven this by being able to hand-start the fan. Once replaced, the compressor should kick in & work fine.
Jul 20, 2012 | Heating & Cooling
We have Goodman AC unit...not sure what kind. It has blown VERY cold until the last few days where it would stay a little above where I had it set. Then yesterday I realized it was incredibly hot. My...
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor.
If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning systems.
Jun 11, 2011 | Heating & Cooling
10inch delta table saw....motor starts slow then kicks off
Assuming that this model has a belt drive from the motor to the saw arbor. Remove the belt and turn the motor on--same problem? If motor is a capacitor start unit, the capacitor may have failed. Be sure to check motor rotation by hand--it should spin freely. If ok, check the turning action of the blade itself--it should spin freely and coast for a little while. If not, check the arbor bearings for failure. Hope this helps!
Dec 22, 2010 | Garden
The motor runs fine with the belt off but when the compressor is on line the motor hums and trips the house breaker.
Turn the compressor pump pulley by hand (with belt off) and air pressure in the tank. It should be very easy to turn. If it is hard to turn, evaluate the check valve for leak. If no leak examine crank bearings for damage. Repair as needed. If easy to turn fault is with motor. Check amp draw with belt removed. When the motor comes on, it should draw about 15 amps and drop lower. The motor should start and reach full rpm in a split second. It should start with a bang and run smoothly with-out getting hot and only pull low amount of amps. If slow start and high amp draw, check capacitor/s and or start winding switch inside of motor. Sometimes the start switch will burn the contacts and give trouble. If both capacitors test within 95% of value and start switch appears to be good, look for damaged copper windings. Windings will be discolored or burned and the tie strings binding the windings will be melted. Replace as needed. Good holidays
Dec 15, 2010 | Dewalt d55170 Electric powered air...
Maytag washer, buring rubber smell, drum won't turn
the drum should run free if not the bearing have gone and seized they will need to be replaced. hear is a video there are others you can find the bearing kit on line using the model number https://youtu.be/WGolkFlgl3Y
Jun 22, 2017 | Maytag Washing Machines
My goldstar turns on and hums, but no cold air. then it blows a circuit breaker
First you should check the power for short circuit, second you have to check the fan motor if it is burnt or not,third check whether the compressor is burnt or not.These are the three reasons.If the powering is short circuited change the cables from the mccb.If the fan motor is burned out replace the fan motor or rewind the fan motor.If the compressor is burnt out replace the compressor, evacuate the refrigeration system and charge the refrigerant.
Aug 15, 2009 | Heating & Cooling
Comprssor hard to turn when cold
yes in winter you should use thinner oil ~~15sae
Jan 29, 2009 | Campbell Hausfeld 26 - Gallon Air...
Hard Starting Dometic Rooftop AC unit
Just add a$10:00 hard start kit to the compressor.
Sep 06, 2008 | Dometic Rooftop RV Air Conditioner
Kicks out?
the smaller belt is causing the tub to spin too quickly. the shorter belt is causing the motor to overheat and causing the thermal overload protector to shut dowqn the motor. when the motor cools it starts up again. replace the belt with te correct size and that will solve your problems
Oct 11, 2007 | Amana NAV2335A Top Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Campbell Hausfeld VH6111 Oil Lubricated 60 Gallon Cast Iron Air Compressor Logo
195 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
