Question about Panasonic DMR-ES10 DVD Recorder
Sound issue watching a chanel on TV but the sound from the dvd recorder, the chanel it is recording comes through to the tv giving two differant sound tracks on the one chanel
  • 11,896 Answers
Try hooking the system up so that it uses a different channel when in use.
Posted on Jan 29, 2009
How do you record from my tv and what channels will I get?
Has this ever worked?
When you mention channel I assume you mean the channel on your TV set. Normally an S-Video input will be an aux input channel and not a numbered station on your set. How do you select the player chanel/ input when you watch the DVD?
Is the arial connected to the PVR then to the TV or direct to the TV It needs t pass through the PVR.
Jun 24, 2014 | GoVideo R6750 DVD Recorder
I have a dvd/vcr rrecorder with no coaxial connection. How can I tape or record a TV program?
Hi,first of all I assume that your Magnavox DVD/VCR Dual Player has the recording features as well..othervise you cant do anything"NEGATIVE" ..If yes than follow the procedure below..
If you want to record your TV program while watching to your DVD/VCR system you need to connect "Video - Audio Output " RCA jacks or "Optic cable output" of your TV or CABLE box to "Audio-Video input or "Optic Cable input" of the DVD
There you go..Your TV's video and sound is on the
DVD/VCR Dual Player Receiver..of course your DVD source input should correspond with the jacks you used on the back...push "RECORD" button it should start for recording the coming signal into DVD
when you recording the output RCA jacks of DVD will generate the signal of whatever records that can be monitored with another TV set after properly connected..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 15, 2011 | Philips Magnavox DVD/VCR Dual Player
How record tv chanels using the DTV converter box? The converter box determines the chanel of interes while the DVD recorder must remain on chanel 3 in my area. My DVD recorder is a combo with a VCR...
Can you connect directly from the DTV converter to the DVD recorder input using RCA phono connector cables? You'll have to select the input on the recorder menu as well.
Oct 21, 2009 | GoVideo Go Video DVD/VCR Combo
I can't record normal tv progrma from HD tv
My dear friend where you connect the antenna source to the dvd or to the vcr or tv because ,if you wanna record anything you need to connect the antenna source to the dvd and put the channel you wanna record on him
Jul 25, 2009 | Televison & Video
With the new HD transfer. We just have atenna...we just bought a HD TV. Is there a way of connecting the DVD Recorder so I can watch one channel and tape another with this new system
A lot of your question depends on your DVD recorder, but there IS a way to connect them so you can watch one channel and record another one.
First - if you have an HD compatible DVD recorder (one that will allow you to select channel 8, 8.1, 8.2, etc) then you could simply split your antenna signal BEFORE the TV or DVD recorder. Then you can select one channel to watch on your TV while selecting and recording a different channel on the DVD recorder. If your DVD recorder is connected to your TV's Video Input, you should be able to monitor DVD recorder's activity by selecting the "Video Input" on your TV.
If you DON'T have an HD DVD recorder, then you will need to get a converter box to put between the Antenna signal and the DVD recorder. You can then set the converter box to the channel you want and the DVD recorder can be set to record it.
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Satelite tv through my dvr-550h
satellite tuners and DVDs have different remote,unless your using a universal remote with satellite tuner command available.to program recording, you'll need to program the time especially the allotment.then make sure you sat tuner is tuned to the station you want to record.after setting the time and station, its all set.you don't need the DVD's remote to change the channel.
May 27, 2009 | Pioneer DVR-550HS HDD Recorder
I am having difficulty when I try to program the VCR to tape a TV show that I am not watching. When I go through the nine steps that are outlined in the manual on pages 24 and 25 the TV will tape for me...
if you are useing a cabel box you need to split your cable before the cable box with a two set coupler and run the second cable line to the VCR input and this should solve your problem. if you want to record the chanels from your cable box and not watch a diffrent chanel you can leave it hooked as is and select the chanel you want to record with your cable box tunner and leave it turned on, set the vcr to record channel 3 or 4 which ever is the channel you leave your tv tunner on and record that way.
Jul 30, 2008 | Televison & Video
Installation
Are you talking about recording from the list? You might have to set the recorder to record chanel 3. I can't check it because my dvd recorder is broken. I haven't done it in a while, I remember going to list and telling tivo to record to vcr and recording chanel 3, but you can't watch tv till it's finished.If you are talking about a connection try an a/b switch. All I can say is experiment
Dec 19, 2007 | TruTech TT1620 DVD Recorder
Watching tv while recording onto vhs or dvd
This could be a couple of problems. I'm not trying to make you feel dumb or anything but sometimes people miss the obvious. Do you have an universal remote? How is your vct wired to your tv? Does your cable go to your vct or your tv first? These sound like silly questions but they are important.
Jun 02, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-ES10 DVD Recorder Logo
64 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
