Question about Garden
Lawn mower stored 4 years. put gas in tank and when pulled cord to start gas poured out of air filter.
2 Suggested Answers
  • 126 Answers
SOURCE: gas pouring out of air filter
carb is gummed up from the old fuel turning to varnish and clogging the jets. while trying to start, its trying to inject fuel, but its clogged and taking the path of least resistance (coming out the air filter).
you'll need to drain the gas tank and remove the carb to clean it out. if unfamiliar or uncomfortable doing this, then take it to someone to do a carb cleaning.
Posted on Jan 31, 2009
Why wont my sabre 17.5 h cv491s lawn mower start
bad plug (replace plug), bad gas (empty gas, remix to mfg specs, refill tank), improper oil to gas ratio (see bad gas), old gas, choke in off position, corrosion between plug & plug wire (under spark plug boot (pour freshly opened coca-cola on corosion then rinse with distilled water repeat if needed)) clogged air filter (clean filter or replace). if you have visually inspected & or tried all suggusted here & still no joy, take it back to store if it is new, or take to repair shop for maintance.
Sep 04, 2014 | Garden
Suddenly cut out whilst mowing the lawn. now wont start, pull cord stiff to pull
Something just like this happened earlier this year with my pressure washer. This is what I did to fix it and now it runs great. Check the oil. If it's black or feels the least bit tacky, drain a pint or two of the oil out and re-add that amount of Marvel Mystery Oil. Now, attempt to pull the cord all the way out, but slowly at first. It should get easier to pull after about 5 pulls. If the mower restarts, let it run for 10 minutes until the Mystery Oil is hot and has cycled around inside the engine. Then drain that oil and refill it with a quality brand of oil. To top it off, either clean or replace the air filter, and put a shotglass of Lucas gas & injector cleaner into the mower's full gas tank. I also do this to my lawnmower and weedeater. It works wonders. BTW...If you're unable to turn the engine over by pulling the cord, remove the spark plug and tilt the mower up, so you can turn the blade easily by hand (use gloves). BUT FIRST MAKE SURE THAT SPARK PLUG IS REMOVED. REMEMBER... SAFETY FIRST! Let us know if this helped you any.
Jun 29, 2014 | Garden
I have a murray 6.5 quantum 22inch blade mower that is a couple years old but was only used a couple times last year. It has oil, it's getting spark but it isnt getting fuel. I removed the air filter and...
Remove the old fuel from the tank. Change the gas filter if there is one. Get a can of spray carburetor cleaner and a can/bottle of fuel line cleaner. Spray carburetor cleaner in the carburetor where you put the gas ( remove the air cleaner) . Pour the fuel line cleaner in the gas tank with fresh gas and try to start the mower. Spary some carbuerator cleaner in the carburetor and try to start the mower a few times.
Jun 12, 2014 | Garden
Craftsman 675 series 190 cc lawn mower Wont start
Take air cleaner off. Shoot some spray carburetor cleaner in the carburetor and try to start Try this a few times to see if the engine will fire.. If it fires or starts then there is a fuel delivery problem. Could be a dirty fuel filter, bad (stale) gas, a dirty carburetor. If it does not start with the carb cleaner, check the spark plug. It may be fouled. Check for spark - take plug out of head. with the plug attached to plug wire, hold plug with a pair of insulated pliers, and touch outside of plug where the threads are to the engine, while some one pulls on the start cord. You should get a bluish spark. If you get a weak spark use a new plug and try again. There should be a bluish spark. Make sure you hold the plug against the engine making good contact. If no spark at all, could a bad magneto.
Getting back to the carburetor. If you think the gas in the tank is stale, drain it out and put fresh gas in the tank. Change the gas filter.
The arburator may be cleaned by pouring a 1/2 can of fuel system cleaner in the gas tank and spraying the spray cleaner down the carburetor throat.
Jun 03, 2014 | Garden
Motor mower wont start
By tipping a 4 cycle motor on a lawn mower or any equipment, you have all the oil and gas running into the combustion chamber and sometimes the oil and WATER will get into the tank. It will need too have the spark plug removed, the engine turned over with the starter to blow the oill, gas, and water out of the cylinder(s), the plug should be either dried and gap reset, and the gas tank drained and FRESH gas put in it. Replace the spark plug prime with just a few drops of gasoline in the carburetor throat and restart and let run to dry evrything. NOTE: An oil change is recommended, too!!
Jan 14, 2014 | Garden
Toro personal pace mower not starting
First check the gas. Old gas after only 3 or 4 months of storage will not fire properly. Completely drain the tank and add some fresh gas. Also take the air cleaner off and check the air filter. It is possible you may have tipped the mower to that side while hosing the grass from the underside. The filter could now be plugged with oil and the motor can not breath. Replace the filter if this is the case. And finally, replace the gasket on the back side of the air cleaner plastic housing that attaches to the carburetor. This gasket if defective or dried out can prevent the primer bulb from injecting gas into the carb when you pump it. Its also possible it fell off if you ever removed this cover which is bolted on with 2 screws. Some dealers even go as far as to put 2 gaskets on to get a good prime. If these simple fixes don't work. You also could have sheared the key way when the motor hit something you ran over in your yard. That will require a shop to pull the flywheel and gets a little more involved.
Jun 03, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Craftsman 6.75hp mower doesnt start
if you left gas in the thing for those two years you need a total rebuild and cleaning of the carburetor. At this point the air filter has nothing to do with your problem.
Aug 08, 2009 | Garden
Gas pouring out of air filter
Jan 29, 2009 | Garden
Garden Logo
117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
