Question about Emerson EWL20S5 20 in. EDTV-Ready LCD Television
Is the emerson ewl20s5 digitally compatible
On trying to reset channels there did not seem to be any way to pick up the digital signals
  • arthurwatt Jan 30, 2009
    The source is cable
    there are xome digital channels
    The EWL 20s5 only seems capable of tuning to analog signals though - can a convertor be purchased or is it useless once all digitalised.
    Arthur Watt
  • Devon Sacco
    Devon Sacco May 11, 2010
    Are they broadcasting digital in your area right now? Are you on cable, satellite, or annenta?
    President:
  • 1,077 Answers
I looked up the specs for your TV. It says nothing about a digital tuner at all. I believe you must get a box from your cable provider. I'm sure that they want to keep you around, so they should give you a cable box for free.
Posted on Jan 31, 2009
I have an Emerson 20" LCD EWL20S5. I am trying to
Contact the authorized dealer for Emerson.
Jul 19, 2013 | Televison & Video
Emerson hdtv does not pick up any antenna signal
With digital OTA TV signals, a lot of things could cause you to fail to pick up a signal on any channel. First, do you have an indoor or outdoor antenna and how far are you from the transmitters for you local stations? Digital signals are either enough to for the tuner to interpret or you get no signal. Next check that the antenna is pointing at your stations' transmitters. Use antennaweb.org or tvfool.com to check the direction for your location. Antennaweb assumes an external antenna and provides a very conservative list of stations.
Check for buildings, hills or tall trees that might block the signal to your location.
If your antenna is providing a signal to several TVs, try a direct connection (taking out the splitter). You may need an amplified splitter to minimize the signal loss. Note: amplifiers (whether at the splitter or part of the antenna) can fail and become signal filters (blockers) instead. The direct connection tests this as well.
If another TV does pick up the signal from the antenna (at this point), then the tuner may have failed. It may also just be a weaker tuner compared to the other TV. Surges (for example, lightning strikes) can cause a tuner failure. In that case, you need a new tuner. (a stand-alone tuner like the converter boxes might work) or try a site like shopjimmy.com, searspartsdirect.com or partstore.com. SearsPartsDirect lists the tuner here: http://www.searspartsdirect.com/partsdirect/part-number/Emerson-Parts/Television-Parts/UTUNATSSP006/0057/528/Model-LC320EM9/0352/0333600?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=50034435&diagramPageId=00001&productTypeId=x&searchModelNumber=LC320EM9&subCompDesc=Lcd%20tv&brandDesc=EMERSON&modelDesc=LCD-TELEVISION&blt=11&shdMod= .
This TV was made by Funai so you may see other TVs that use the same part.
I hope this helps.
(I have two TVs with different quality tuners. With one, when the antenna shifts slightly out of place, I can lose the ability to tune in the channels from the closest transmitters. The other TV does not lose the signal until the antenna rotates more than 90 degrees from its usual position.)
May 27, 2012 | Emerson LC320EM9 32 in. LCD HDTV
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Is emerson ewl20s5 tv digital or do I need a converter box?
The set can recieve analogue transmissions or cable signal only, for digital transmission a converter box would be needed
Mar 05, 2011 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
CHANNEL 9 NO SOUND SAP SHOWS AT BOTTOM OF SCREEN
reset the SAP button for CH 9, go through the menu to audio and switch to off........using remote or manually
Aug 13, 2010 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Not picking up Digital signal from box but can receive it analog
So many factors could be affecting your reception. Keep in mind that the digital signal is all or nothing, either you have a signal or you don't, with the regular signal you can pull in weak signals but you can't with digital. Your converter box when turned on will probably not pick up the standard signal. The distance from the digital signal and the direction the antenna is facing also will affect your signal.
Ok with that said you will have to clear the path between the broadcast signal and your antenna, I know this will be a chore but take your antanna out of the attic and put it outside as a test only, this dosnt mean you cant have it in the attic it will just be a signal test.
Once the antenna is moved, from the menu scan for channels and see what you get. Let me know and I can help further.
lone99star
Jan 09, 2009 | Emerson EWL20D6 Television
Digital tv not picking up digital signal??
According to the manufacturer, the EWL20D6 Television is not digital ready. If that is the case then you will have to use a converter box in order to receive the digital channels.
Dec 20, 2008 | Emerson EWL20D6 Television
Digiatal tuner
I doubt it. EDTV "ready" usually means that it can read a digital signal if you have tuner. If it were to say "intergrated" that means the tuner is built into the t.v. and you would not need to purchase or rent a tuner.
Dec 05, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Analog or Digital?
This tv is analog, EDTV is only enhanced definition tv ,480p resolution, not the HDTV 1080i or 1080p resolution, the mts/sap tuner has to do with the audio decoder. For example: SAP would allow you to view a station broadcast in english to be heard in spanish. MTS is surround sound broadcast. Thanks
Apr 02, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Emerson EWL20S5 20 in. EDTV-Ready LCD Television Logo
216 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
