Question about Hoover U5720-900 WindTunnel Upright Vacuum
Hoover u5720-900 quits running and restarts again after some time
I use my vacuum and after about 3 or 4 minutes it just shuts off. After about 10 minutes it will work again but shuts down after another couple minutes. I cleaned everything thoroughly and made no difference. Please help I have to repair shop were I am. thanks
  • 2 more comments
  • Jim saarde Jul 30, 2007
    The filter under the canister is not the solution. It was clean as can be.
  • Anonymous Nov 11, 2008
    I'll vacuum for about five minutes and the vacuum will shut off. It will restart in about half an hour but again will shut off after running only for five minutes.
  • Anonymous Mar 23, 2014
    Phantom Thunder will not turn on. It shut off after being used for thirty minute.
  • Anonymous Mar 28, 2014
    Vacuum shuts off after approx. 5 minutes of use. Will start OK after 1/2 hour. Try again and it shuts of again after approx. 5 minutes. Thermal sensor issue ???
There is one more filter under where the collection tank & Hepa filter sits -- there is one screw that holds the cover down - remove that filter and clean it that will help. I also find I need to vacuum the hepa filter as well- it is too expensive to replace all the time. The Hepa filter can be placed inside a plastic bag and shaken really good to get the dust off of it
Posted on Jul 27, 2007
Vacuum shuts off while in use
There is a thermal reset inside the motor that shuts it off. There may be a clog.somewhere or something restricting the airflow, it could be clogged filters. If there are no clogs or restrictions it is possible the thermal reset is bad in which case you will have to replace the motor.
Jan 26, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover vacuum shuts off after 10 minuts of use.
If there is no clog the filters may need replaced to improve airflow
Jan 21, 2014 | Hoover Vacuums
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
My Hoover runs for a few minutes and shuts off.
It's possible the thermal reset is defective. It shuts the motor off if it gets hot. Remove the bag door and take the bag off, remove both filters and then turn the vacuum on, just leave it sit there with the motor running. This eliminates the bag or filters causing any airflow resistance. If it still shuts off after a few minutes it's likely the thermal reset is bad. Some vacuums have an external thermal reset button which can be replaced if necessary but on your model it is built into the motor and you must replace the motor. If the motor runs fine put the bag and the filter under the bag back in - (make sure the filter is clean and not restricting airflow) put the bag cover on then turn it on again. If it overheats and shuts off then you may have a clog on there somewhere restricting the airflow. If so check the power nozzle area, the hose coming from the power nozzle, the extension hose and wands for clogs or restrictions.
Sep 22, 2017 | Hoover U6426-900 Bagged Upright Vacuum
My hoover vacuum runs for about 10-15 minutes then the saftey feature shuts it off(overheat?). i have taking it apart a cleaned it with no results, added new bag also. after an hour it cools down and works...
Do you have suction through the tools? Does it look like it picks up when it runs? The machine could be clogged and that would cause the problem, but unfortunately the sensor that shuts the machine off could be bad if the machine isnt clogged. Its not easy to get to it, I'd take it to a repair shop.
Sep 16, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
After I run my vacuum for a couple of minutes it shuts off. If I unplug the vacuum and plug it into a different outlet most of the time it will start working again.
I would say check inside the plug and make sure the connections are tight. If the vacume runs fine on the other socket outlet then it will bw a faulty socket which cuts your hoover out. Can buy a new socket frount from diy stores for about 2-3 pounds. If the hoover also cuts out on the other sochet it will be a temperature cut out device on your hoover. If this is the case empty the bag and give it a good clean and get rid of any accumalation of dust/dirt
Jun 24, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Windtunnel shuts off after a few minutes of use.
yes i think i can help. all new hoovers have a thermal motor senser that turns the motor off wen it heats up to a certain point mine hade the same problem so i toke it apart and the bering in the motor was worn and heating up and tripping the senser if u have wd40 put some on the bering and be shure to wipe excess wd40 off so it doesnt get in the wires.
Feb 03, 2009 | Hoover U5450-900 Windtunnel Supreme Bagged...
Hoover Floormate won't dispense clean solution
The tank sits on what is called a reservior asm, that may have gone bad. Does the water flow out of the tank when you push in the valve at the bottom?
May 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover mach 5 only used 3 times
If the filters are ok, and there is no clog in the hose or dirt inlet down by the brushroll, then the motor protector is probably bad.
Mar 13, 2008 | Hoover Commercial C1660-900 Bagless...
Hoover U5720-900 WindTunnel Upright Vacuum Logo
478 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
