Question about NexxTech 400W Power Inverter (2218400) UPS System
Fan has not turned on
Is fan only supposed to come on if inverter overheats?
    Problem Solver:
  • 20 Answers
I think the fan should work all the time. There might be and option in the software to turn on the fan only if the system overheats.
Posted on Jan 30, 2009
3e227e.. flames turn on, no fan. Flames turn off..
Hi Peter:
Sounds like the Calgary NHL Hockey club.
Seriously. If the fan is not working the unit will overheat and turn itself off. That's the safety aspect doing what it is supposed to.
I'd start checking the fan. Electrical supply, switch, whatever is supposed to happen to get power to it. Then, if it is getting power but not working, you'll need to find out what is wrong with the fan motor.
Reply as a comment to this post and I'll do what I can to help.
Cheers.
Dec 30, 2015 | Heating & Cooling
Overheats unless ac is running
The thermostat may be stuck. If it dosent open then the engine will overheat. If you turn the ac on then the air rushing around the engine will help cool it down. Replace the thermostat and it should fix it
Dec 30, 2012 | 2008 Pontiac Grand Prix
Engine cooling fan only works when ac or defrost is on
if engine at long stand still,the engine temperature will rise about 190 degrees the cooling fan suppose to automaticaly turn on when coolant temperature sensor get hot it cause its resistance decrease causing pcm to send power to coolant fan relays and cooling fans, when you turn on AC the cooling fans suppose to turn on to cool down AC CONDENSOR, IF NOT AC WONT WORK COOLING FAN COOLS DOWN REFRIGERANT SO IT CAN RECYCLE THROUGH THE SYSTEM AGAIN.your cooling is suppose to turn on when engine at a sit still if vechicle not moving as coolant temperature rises at a set point the cooling fans will turn on cool down engine.cooling fans dont turn on when you first cold stsrt vechicle unless you have AC SWITCH ON.if cooling fans dont turn on when vechicle at a long stand still or moving along slow traffic.if coolant temperature sensor been replaced and fuses and relays okay have dealership check see if pcm driver circuit working faulty pcm will cause cooling fans not to turn on.
Sep 27, 2012 | 1996 Buick Century
Car overheat when first run turn car off and back on and car run cool
You might need to replace fan assembly and/or thermostat. Mine was overheating only when stopped at traffic lights. Only one fan was working and would cause the car to overheat. Working great after fan swap.
Jun 20, 2012 | 2002 Dodge Intrepid
I recently purchased a schumacher 410w inverter, while it came on right away and powered my electrical device the cooling fan never came on. Is the fan supposed to run all the time, once its connected.
I recently purchased a Schumaker 410/820 watt inverter. I immediately hooked it up to a brand new deep cell batery I had purchased just prior to receiving this inverter.
I plugged in several devices to make sure the inverter worked and to get some idea of what devices I can expect this unit to handle.
I noticed that the fan only ran when I plugged in a device that drew a certain amount of power from the unit. I also plugged in a CPAP unit to make sure the inverter would operate the unit properly, and noticed that the CPAP only drew 38 to 40 watts of power and the cooling fan on the converter never came on. When I plugged in an oscillating fan it drew around 128 watts from the converter and the cooling fan immediately came on when I turned the fan on. Based on that, I would assume that the cooling fan in the converter only runs when there is enough power being drawn through the inverter to cause the inverter to heat up enough to cause possible damage to or failure of the inverter. I haven't taken the time to find out the power draw at which the cooling fan will run. Hope this helps.
Jul 10, 2011 | Schumacher 410 Watt Power Inverter...
2004 pacifica radiator overheats every couple
A fan is on or off not slow do any fans in your house run slow because they are old?Your thermostat fan or temp sensor is bad
Jun 27, 2010 | 2004 Chrysler Pacifica
1989 camaro cooling fan failure, how do i fix it
When was the last time the thermostat was changed , the fans are only supposed to come on before the temp gets to high if the fans come on when you turn the air conditioner on then it is not the fan.
Sep 07, 2009 | 1989 Chevrolet Camaro
Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Feb 26, 2009 | Vector VEC056 MAXX Power Inverter
Computer freezes constantly - has to be hard rebooted
HI it can be true if the fan stops processor overheat to prevent overheat. it should work all the time (when your pc is on ;))
Aug 15, 2008 | IBM ThinkPad T30 2366 Notebook
Heat vents
The vents on the side are sufficient - but the fan should run when you turn it on. If the fan is broken or worn out, your computer will overheat and crash - fans can be replaced but a technician or service shop would need to do it, it's not easy to get laptops open. So, to fully answer your question, there is not supposed to be a heat vent on the bottom. But the fan should probably be running when you turn it on. If the seller of the laptop didn't mention a broken fan you might want to contact them and ask if they know.
Jun 10, 2008 | Dell Latitude D600 Notebook
NexxTech 400W Power Inverter (2218400) UPS System Logo
334 people viewed this question
Top NexxTech Computers & Internet Experts
Informat...
Informat...
Steven Wander
Steven Wander
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
