Question about Garmin nuvi 255W GPS Receiver
Nuvi locked up wont shut off or do any thing
Is there a reset button? where?
  • Anonymous Feb 08, 2009
    I have a similar issue to mdinc3's where, having downloaded new software from the Garmin site, the instructions were to unplug the device from the computer, then reconnect when the 'where to' screen appears. But the device has seized up showing just the Garmin logo and 'Loader loading....' on the screen. And the reset button doesn't appear to exist.
  • ctandcarolt Feb 16, 2009
    new Garmin 255 is driving me crazy. it's in Spanish and I can't figure out how to change it to English.
  • 4 Answers
Try holding the slider "on" until it resets. the 255W doesn't have a hard reset button.
Posted on Feb 13, 2009
  • Garmin Master
  • 2,130 Answers
Yes, on the bottom where the decal is. It's located on the left side. You might have to use the point of a ball point to press it.
- Jim
SHARCNET-USA
Posted on Jan 29, 2009
  • SHARCNET-USA
    SHARCNET-USA Feb 09, 2009
    That is actually normal and it will say that for several moments. You should not try to turn it off while it's doing that.
  • talkclear Apr 15, 2011
    I removed the sticker and this version of the 255w does not have a reset on it. The only way to reset it is to either hold the slider for 5-10 seconds or do a hard reset by putting your finger in the lower right corner as you power it on. My 255w also freezes at the most inopportune times, despite the fact that I updated the firmware. It actually became worse when I updated it. Another thing, the gps is very affected by cold weather. If you leave it in your car and it is cold and try to use it, my experience is that it will indeed freeze up and there is no way to shut it off or get it to function at all.
Wont caculate
If your Nuvi won't turn on, it's possible that it's locked up. Try using the reset button as follows.
Nuvi 3xx & 6xx Series: The reset is located on the rear of the unit, underneath the antenna. Press and hold it for at least 8 seconds and then release.
Nuvi 7xx Series: Slide the On/off power switch to the left and hold for at least 8 seconds and then release.
Nuvi 2xx & 2xxW: There are (2) different versions of this series.
Some will have the reset on the bottom, where the decal is. There will be a small flap labeled "reset".
On newer units, slide the On/off power switch to the left and hold for at least 8 seconds and then release.
Oct 23, 2010 | Garmin Nuvi 465T Car GPS Receiver
Just used garmin nuvi it worked fine went into the store and now the unit is locked/frozen on the garmin logo screen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The reset button on your nuvi 2xx, 3xx or 6xx will not restore your device to factory settings or delete any map updates. The reset button will switch your device off if you are unable to switch the device off by the power button. It will not erase any data on the device.
The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Make sure to charge it fully.
Dec 29, 2009 | Garmin Nuvi 660 GPS Receiver
My Garmin Nuvi will not turn off.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
  1. Lift the antenna
Aug 03, 2009 | Garmin nuvi 260W GPS Receiver
Garmin 260W screen is blinking and beeping. Wont do anything else
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sure give it a try.
  1. Lift the antenna
Aug 02, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Garmin 255W turns on and shuts off
Have you tried resetting the unit.Press and hold the RESET button on the bottom of the nuvi for several seconds,DONT use a ball point pen to do this,use something that wont damage the unit,if this doesnt work,do a hard Reset.Or try rebooting by holding the Power switch on for 15 seconds.Good luck.
Jul 23, 2009 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 260w wont turn on. I used a charger that it wasnt used to and the whole thing just shut down. It wont turn on i tried the origanal charger, i tried pluging it into my computer, i even tried...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu.
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on. Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on.
May 31, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
My garmin nuvi 660 na is locked and i cant unlock it
There should be a small pinhole for a reset button. Press and hold this reset button for 60 seconds. Then turn the device back on.
Mar 25, 2009 | Garmin Nuvi 660 GPS Receiver
BROKEN GARMIN NUVI 260W
Have you tried pressing the reset button on the bottom where the decal is?
Dec 18, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi stopped working and won't restart
Got a Garmin Nuvi 260. Same problem. I read the booklet. There's a reset button on the bottom. Disconnect from power. Push the reset button. Connect back to power. Now it works. The reset button is tiny and looks more like just text on the bottom sticker than it does a button. But push it anyway.
Aug 06, 2008 | Garmin nuvi 350 GPS Receiver
Garmin 660 locked up / frozen
Resetting the device merely resets the power connection, on some devices there is a reset to manufacturer defaults on settings, but not your stored data. Working with GPS's 40 hours a week I constantly have to use the reset button when they lock up. Just press it in for a few seconds then if it doesn't power back up just hit the power button and everything should be fine.
May 09, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
3,015 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
