Question about Sharp Audio Players & Recorders
Belt on turntable needs replacing
Sharp SG400E 1980's music centre, thought tuntable would lift stright off, 1/8th of an inch travel then locks
  • johnkeddie Jan 29, 2009
    thanks, would you believe, it did lift off, i did'nt want t force it but eventually it gave...thanks
    Scholar:
  • 140 Answers
Should have a retainer clip of some sort right in the center of the platter. Should look something like this, you will need to take it off first.
Posted on Jan 29, 2009
Reconnect the belt on an AIWA PX-E860 turntable
To replace a turntable drive belt.
Before starting any work on your turntable disconnect it from the mains power supply. Remove the stylus or complete headshell to prevent any accidental stylus damage.
1. Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes either side of the centre spindle and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter and motor pulleys with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure it is sitting flat without any twists.
5. Flip platter over to the right way up. A correct fitting belt will stay put and an over sized belt will fall off.
6. You will see 1 or 2 large rectangle or square shaped cut outs in the platter near to the outer edge. Through one pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
You have now successfully completed the process.
MUSIC IS LIFE, LIVE IT LOUD.
Copyright.. Styluscity, John Harrison.
Dec 16, 2014 | Aiwa PX-E860 Turntable
Toshiba Stereo Music Centre SM-D30,Turn Table, SX-N330 Speakers
Try:
http://www.vintage-electronics.net/toshiba-sr-f225-belt.aspx
If the turntable has a two-piece platter, Lift off the outer platter and place the belt around the inner platter and motor pulley.
If the turntable has a one-piece platter, lift off the whole patter, place the belt around the inner drum. There will be a hole in the platter's top through which you can reach a finger to stretch the belt so that the belt can be placed around the motor pulley as you put the platter back in place.
Aug 25, 2014 | Audio Players & Recorders
I need to put the belt back on my JVC al-a158 phonograph
To replacea turntable drive belt.Copyright.. Styluscity.com, JohnHarrison. Nov 2011Before starting any work on yourturntable disconnect it from the mains power supply.Remove the stylus or completeheadshell to prevent any accidental stylus damage.1. Remove the rubber platter mat toexpose the platter.
2. Put your thumb and forefinger through the two round holes either side of thecentre spindle and lift the platter off. You may need to give the centrespindle a light tap (whilst applying upward pressure) with a screwdriver handleor some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter and motor pulleys with an alcoholswab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure it is sitting flatwithout any twists.
5. Flip platter over the right way up. Acorrect fitting belt will stay put and an over belt will fall off.
6. You will see 1 or 2 largerectangle or square shaped cut outs in the platter near to the outer edge. Throughone pinch up the belt and slip a finger or belt hook between the platter pulleyand the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter backinto position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotationto ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correctoperation.
MUSIC IS LIFE, LIVE IT LOUD.Styluscity.com cansupply replacement drive belts for all turntables
Nov 12, 2011 | Audio Players & Recorders
Need to replace the belt on my JVC AL-A95 turntable
Oct 08, 2011 | JVC AL A158BK Turntable
My PL120 turntable purchase new skips often and will hardly work with music played at a loud volume
The first problem could be the stylus needs cleaning. Please shine some light on the stylus ( needle ) and see if it has picked up dirt from the record groove. This will prevent the stylus from tracking the song properly. Clean using a fine brush in the direction in which the stylus passes the record groove i.e from back of the pick up arm to front- NEVER SIDEWAYS.
Next check the counterweight adjustment at the back of the Pick up arm. The tracking force should be between 1.5 to 3 grams depending on the brand of the cartridge. What ever be the chosen weight the antiskating knob should also be set to the same number.
The skipping can also be because of heavy bass vibration traveling up the body of the Turntable.Good turntables have a floating suspension to prevent this. The tuntable platter will be suspended on springs.You can place it on a rubber Matt or move it away from the speakers ,esp: sub woofers.
Apr 06, 2011 | Audio Technica AT-PL120 Turntable
Just bought a new technics sl-1200 turntable and the pitch speeds up and down causing music to sound funny....
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Dec 03, 2009 | Technics SL-1200 Turntable
Belt fell off
HI, First remove mat from TT platter. Next hold it with upward pressure while striking centre pin with a sharp tap, (real light instrument) not blow. Next you will see the motor shaft (once TT is removed) note it's position, put belt back onto TT rim, that will be the underside flange, lift belt by one finger away from flange edge and place TT back over spindle while having finger with belt over motor shaft. allow belt to contact with motor. Now belt should be around under platter flange and around motor pulley. If this is correct, power up, if all works replace soft mat and enjoy the music. A word of warning, the belt and stylus/cartridge may need replacement!
Aug 25, 2009 | Sony PS-LX250H Turntable
How do you start up a tuntable?
Look for a switch that has 33 and 45 unless the hole in the middle of the record is rather large turn it to 33.
Jul 31, 2009 | Crosley Traveler Turntable
Belt replacement
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all turntables including yours that will show how to install the belt an a few other things.
Nov 08, 2008 | Aiwa PX-E860 Turntable
JVC turntable LA10
The trick is to lift up on the platter (tothat metal on metal feel that you had) while simtaneously "lightly" tapping on the top of the shaft with a hammer. Trust me it will work as just changed my belt.
Hope that helps.
Mar 16, 2008 | Audio Players & Recorders
215 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
