Question about Campbell Hausfeld 26 - Gallon Air Compressor
Comprssor hard to turn when cold
My compressor has difficulty starting when cold and the belt burns a little until it starts spinning freely. Can I use a lighter weight oil than 30 for winter use?
  • 142 Answers
Yes in winter you should use thinner oil ~~15sae
Posted on Jan 30, 2009
What is wrong...My Eureka commercial vacuum C2094g smells like burning rubber, replaced belt (style RD) but it was smaller in size and very hard to put on. Am I using the wrong belt? it looks like the...
Replace the Roller Brush. Sounds like bearing in it is locking up and the the belt is slipping and not turning the Roller Brush as it has a locked up bearing. You will need to go ahead and get a replacement belt just in case you have stretched the older belt to a bigger size. I had this same experience with a Hoover and it solved my problems of "rubber burnt smell".
Apr 27, 2014 | Hoover S3765-040 WindTunnel Bagless...
Spin cycle doesn't work
I don't know if this applies AT ALL, but if it does, then it would be an easy fix. If your washer isn't like mine was, then just ignore the following:
Start by popping the cap on the spindle inside the drum, it just has a plastic cap that pops off. With that cap off you can try turning the little doodad inside one way and then the other, and it should "ratchet," catching and making the spindle turn when you turn it one way, but freely spinning the other way. IF it freely spins BOTH ways, the pawl dogs are worn. This is what was wrong with mine, and the pawl dogs are cheap and easy to replace. To get to the pawl dogs themselves you would just need to loosen one bolt head under that cap, and lift the assembly out, and then the pawl dogs are on that assembly.
Mar 06, 2014 | Kenmore 24032\24036 Top Load Washer
Smells like burning rubber
sounds like a bad bearing take the belt off and see what pulley is hard to turn look for the one with dark marks on it from the belt
May 12, 2012 | Craftsman Garden
The Electric motor does not have enough torque to start compressor. It is hooked up to 230V with 40 amp single phase. checked voltage with meter so I know it has enough voltage.
Does it trip the breaker or does the motor just hum and not turn the compressor? The motor may need a start capacitor. Do not keep tryin to start you can burn out the start winding on the motor.
TURN OFF POWER AND LOCK OUT.... try and take the belts off (if it has belts)of the motor and compressor and make sure both turn freely. IF THEY TURN FREELY THERE IS A PROBLEM WITH THE MOTOR. You said voltage, wire size and breakers are the right size.
Hope this helps you with your problem...Jim...please leave a comment
Feb 13, 2011 | Ingersoll Rand SS5L5 Ir Electric...
A/c compressor is seized, i think. when the engine's is running the belt is squeals. looking for ideas about getting it to spin freely until i can afford to fix it
If the A/C clutch is in fact seized, there isn't an easy fix. take the belt off and verify that indeed that pulley won't turn or turns with great difficulty. Since there is only one belt, you have to address the issue. Depending on the belt routing, you might be able to get a shorter belt and bypass that pulley.
Dec 23, 2010 | 2004 Kia Sedona
I have a bissell easy vac and the metal part that spins the rubberband and brush keeps overheating and burning all the belts I replace. What should I do?
Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly. If the belt is missing and you need to replace, I would still do the cleaning on the beater brush. It should move freely when you turn it by hand.
Sep 13, 2010 | Vacuums
Serpentine belt slips off idler pulley
The A/C pully is supposed to spin freely until the AC is activated to run.. The cranshaft pully does not. Replace the tensioner pully. The belt has to fit in between the grooves on the pullys.
Apr 05, 2009 | 1994 GMC Suburban
Squeling noise when cold
The right side of the car are where the belts are located. Start by checking their tension and inspecting them for cracks and/or glazing, this would be a sign of slippage. Older belts are not as pliable and will stiffen significantly after cooling, causing a squeel. While the belts are off, spin the pulleys of the alternator, power steering pump, water pump and AC compressor clutch. They should all spin freely with very little to no resistance and no noticeable bearing noise. If there is a 'grinding' feel to any of them as you spin them, it's possible that particular component is failing and causing the belts to slip.
Mar 31, 2009 | 1997 Toyota Tercel
Compressor hard to start when cold
sounds more like the pressure relief valve that takes the air pressure off the compressor upon shut down so when it re-starts there is no pressure until the motor gets a start this is known as a unloader valve and is usually a small brass valve that looks like a fitting and will hiss on shutdown,if it sticks the motor trys to start with the load of the air pressure on it and slips the belt due to load
Jan 29, 2009 | Campbell Hausfeld VH6111 Oil Lubricated 60...
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
145 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
