Question about JBL On Stage Micro Portable Speaker Dock for Apple iPod - Black
Want to hook up an IPOD to professional sound equipment.
I want to hook up an IPOD to a professional sound equipment. I have access to this equipment and want to compile a playlist on my IPOD for a party. What equipment do I need to have to do this..... Are there any impedience issues that I need to be concerned about, etc...
    Scholar:
  • 140 Answers
Shouldn't really need any equipment. You can use a RCA to 1/4" phono adapters.
One for the right and one for left.
If you mixing console already has RCA input then you don't need an adapter.
Make sure you set the volume level on your ipod around 1/4 to 1/2 way up and then turn up the channels your piped into. If the faders don't give you enough gain (volume) then turn up the ipod I bit more. Just watch your imput signal and make sure your not clipping or the sound will be distorded.
Should be straight forward.
Posted on Jan 29, 2009
How do i hook up and ipod and/or computer to the Gem Sound CMP500
you need to connect the player to a dj 2 channel mixer using a red and a white RCA CABLE ...(line 1) then into (line 2) ... from pc /laptop ... need a stereo mini jack to 2 RCA (RED / WHITE) INTO back of the mixer ... before turning on please remember to set volume on pc/laptop 80% MAX ... and DISABLE EQ's or FX ... dj mixer has all the EQ / FX needed :
Mar 05, 2013 | Gem Sound CMP500 Dual CD / Mp3 / USB...
Tip
How do I connect my iPod to a stereo Kenwood
<p>The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod. <br /> <p><br /> <p>1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see. <br /> <p><br /> <p>2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack. <br /> <p><br /> <p>3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected. <br /> <p><br /> <p>4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off <br />
on Aug 09, 2011 | Apple iPod touch
Can't get sound out of Boston soundbar when hooked up to 46" LCD Philips? Soundbar works fine when hooked directly to iPod.
You may have to go into the settings on the tv and turn off the internal speakers in order to get audio out of the jacks on back.
Dec 27, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
My iPod is disabled what can ido
You can hook it up to your computer and in iTunes go to your device and on the front there should be something like restore or recover iPod, click that and you will be able to access your iPod again
Dec 30, 2011 | Apple iPod touch
Ipod cant hook up to itunes or turn on
try putting your ipod in DFU mode. after putting your ipod in DFU mode restore it. that will the problem.
Jul 23, 2009 | Apple iPod touch
Ipod hook up
YES you can!! Touch the "video" button on Jensen, theyou MUST use your iPod to findthe video you want to play on the screen and SET YOUR iPOD SETTING TO "TV OUT"!! I have the same decand iPod and it's GREAT!! Just remember that on videos, set the iPod to TV OUT, and control the video from the iPod!!
Enjot man,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 22, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Ipod will not turn on
there seems to be something wrong with the battery, I would contact apple, your dealer, or a local professional.
Get the battery checked.
Mar 31, 2008 | Apple iPod nano 3rd Generation
Ipod wont come up
The problem is that your iPod adapter does not have a authentication chip in it. Apple decided to go a new route with the new iPods. They now require a authentication chip if you want to get audio and video out of the iPod using the dock connector. So you won't be able to hook up your iPod to your system using your current equipment. You can either hope that the maker of your equipment comes out with a new iPod cable that has a authentication chip (they have to pay Apple for this so if the company is cheap then you are probably out of luck) or just stick with your older 5G/5.5G iPod.
Mar 18, 2008 | Dual XDVD8181 Car Video Player
Sound Issues
The player has a built in safety device which only allows it to turn up so high. It help to avoid burning out your equip ment. Best way is to put sound on one device 3/4 ways up and then use the other device for adjusting the volume from there.
For sound in one channel; either there is a wire unplugged or not getting a good contact, or the player is set for mono instead of stereo
Jan 22, 2008 | Alpine CDA-9856 CD Player
JBL On Stage Micro Portable Speaker Dock for Apple iPod - Black Logo
235 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
