Question about Technics SL-MC7 110-Disc CD Changer
MC300 Technics drive belt
I am looking for a drive belt for a Technics 110 CD player Model SL MC-300
2 Suggested Answers
SOURCE: Looking for a drive belt
A rubber "O" Ring as a belt solved the problem.  At our local hardware store:  1 1/16 OD x 15/16 ID - 1/16" wall  $0.39!
Posted on May 21, 2009
Where can I have the unit repaired. It is stuck in search mode.
might be just a broken drive belt - pretty common on these units. Take the cover off and look at the top of the cd mechanism for the belt.
Feb 08, 2016 | Technics SL-MC7 110-Disc CD Changer
Stuck in "checking discs" mode
Obviously your device is not working and you should seek professonal assistance..
Jun 08, 2015 | Technics SL-MC7 110-Disc CD Changer
NEED A BELT FOR TECHNICS DISC CHANGER MODEL NUMBER SL-MC400
take the belt to your local ace hardware and look for an o-ring that is slightly smaller than the stretched out belt. this will work just as well.
Mar 01, 2015 | Technics SL-MC400 110-Disc CD Changer
When i turn my technics cd player all i see is error
Technics CD Changer SL-MC400
The ERROR Is Cause By The Belt Drive
Remove The Cover And You Can See if
The Belt is Lose or slip of In Any Case
You Must Change That RUBBER DRIVE BELT.
Dec 31, 2013 | Technics SL-MC400 110-Disc CD Changer
My disc changer technics slmc60 goes through its motions then keeps coming error
The changer mechanism has two drive belts which wear out over time. The wear throws the synchronization out of wack. Panasonic does not stock replacement belts as I found out when my SL-MC-300 failed, BUT thanks to a smart indivudual who looked at my problem I found out that square-cut o-rings (as in plumbing) could be substituted. Be aware, though that when I worked a similar problem it turned out to be the laser assembly that was bad
Feb 24, 2013 | Audio Players & Recorders
Technics SL-MC-7 Multi Disk CD Player- When I put a CD in it says
What does it stay? I am (Hooch) Please get a different CD (PLayer) I have (Retired)
Nov 09, 2012 | Technics SL-MC7 110-Disc CD Changer
Hi i have a techniqka hi fi MC-208 when i put a cd in it plays for a bit then 0P shows on the wee window so i cnt play cd... How can i resolve this... Thanks Kerry
try to turn it off an on while holding the play button. try 2 go online an look for the meaning of your (op). type in .technics sl-mc-208 cd player 0P problem
Mar 15, 2011 | Technics SL-MC50 CD Player
Looking for a drive belt for a SL MC300 Technics 110 CD changer
Jan 29, 2009 | Technics SL-MC7 110-Disc CD Changer
Technics SL-MC7 110-Disc CD Changer Logo
204 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
