Related Tags:
This problem should be removed because:
Problem with Apple iPhone Smartphone
downloading contacts from Palm to iphone
I want to download my contacts from my Palm Pilot to my Iphone
Solutions (11)
Best Solution
Just save the contacts as described above "Bring up Palm Desktop. Make sure your Palm phone is
sync'ed up. Show the Address page, select all contacts
(Ctrl-A), and export them with File, Export vCard...
This puts all contact information into a single file as a sequence
of vCards."
Then send the file you saved as an e-mail attachment - using any mail (i.e. gmail, yahoo, outlook, etc) - to your i-phone e-mail. Open this email on the i-phone and push the attachement - it then asked you if you want to add these, click (push?) yes, and select eithr merge or new and voila you got them.
I have a palm centro that I had to do this for. Open your palm desktop application, goto addresses, goto edit and select all (which should highlight all contacts in your address book) then goto edit and forward as vCard which will prompt your email screen to open (need outlook acct first) then using the outlook email send to your email address which you'll receive on your iphone. From there open your email file which shoul prompt you from there to save all contacts to your phone.
Get Companionlink. You'll need to open a gmail account (it's free). Then you'll synch your palm contacts and calendar to gmail, and from there to your iPhone.
You can use iSync if you have a Mac to transfer Palm contacts and calendar to your new iPhone or iPod Touch.
I moved Palm contacts to my new iPhone by first downloading Palm Desktop software for Mac onto my new Mac laptop. Then I synched the Palm Pre with the Mac, which put all my contacts on the Mac. I then followed instructions from solution #4 above, "Show the Address page, select all contacts (Com-A), and export them with File, Export vCard...This puts all contact information into a single file as a sequence of vCards." Saved this onto the desktop, then just dragged the icon into the "Contacts" icon in the row of icons at the bottom of the screen. Done.
Hi Friends,
Problem with Apple iPhone? Most of the iPhone problem is Unlocking problem.
If you want to unlock your iPhone now you must Click Here.
If you have any other problem with your iPhone you can try the site by Click Here. May the site can help you.
My wife and I just bought an iPhone and wanted
to transfer our contacts from our Samsung i500 Palm phone.
All the instructions I found online suggested going through
Outlook, but that didn't work for me for a variety of reasons.
I found this other method that worked really well.
- Bring up Palm Desktop. Make sure your Palm phone is sync'ed up. Show the Address page, select all contacts (Ctrl-A), and export them with File, Export vCard... This puts all contact information into a single file as a sequence of vCards.
- Bring up Windows Address Book. You can find this in Start, All Program, Accessories, Address Book.
- Using Windows Explorer, drag the vCard file you created in step 1 to the Windows Address Book window. I had never used Windows Address Book, so it was empty. If yours isn't empty, you'll have to decide whether you want to merge your contacts.
- When you drop the file, you'll get a window asking you to confirm the first contact. Press OK. Another window will come up for the second contact. Press OK until all windows are gone. It's easiest to hold down the Enter key.
- Bring up iTunes with your iPhone plugged in. Go to your iPhone page, to the Info tab, and configure it to sync from Windows Address Book. Click Apply in the lower-right corner of the window.
- Sync your iPhone. Verify that your contacts transferred over.
- Tell iTunes to stop sync'ing with Windows Address Book, since you probably only wanted a one-way sync. Your contacts will be backed up anyway by iTunes, so the Address Book sync feature doesn't buy you much.
Waow !, impressive and efficient, I've been searching that solution since I've got an Iphone 4 and it works just the the same way with it.
No need to use µsoft Outlook
the process to transfer 340 contacts between a Palm Z22 to a Vcard file, open this file in windows address book and synchronise it with I tunes to my Iphone4 took nearly 5 mn.
Thanks a lot guest !
I've been trying for two Months to transfer Addresses from my Palm TX to my iPhone4. This worked great. I had to use an old Dell Note Book for the Windows Address Book, and I put iTunes on the Dell. I tried doing it on my iMac, but it wouldn't recognize the vCard File. This is the easiest way to get your Addresses from the Palm to the iPhone. Thank you.
Find your solution from the list,
Apple Iphone Smartphone
Codes:
Software & Hardware Problems
Find Solutions for other Apple Products:
Apple Iphone 3G
Apple iPod Touch Digital Media Player
Codes:
Apple Iphone 3G
FIND YOUR SOLUTION FROM APLLE.
HERE IS YOUR SOLUTION
www.apple.com/iphone/prob237ji32/solution
Thanks
Sync your palm to outlook, then sync your outlook to your iPhone. It'll grab the outlook contacts and calendar.
I've done this for a couple of iPhones now.
Suggested Solution (1)
Here is a "how-to" tutorial:
http://edweirdo.blogspot.com/2009/05/palm-to-iphone-migration-guide.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
This is how you transfer your info from a PDA to an iPhone in Windows:
Important FINAL step:
I want to download my contacts from my Palm Pilot to my Iphone So I loaded the contact list from my Palm to the Windows Address book but...
I have a new iphone, and have used a palm pilot...
How do I transfer information (calendar and contacts) from my palm pilot T/X to my new iphone?
Transfer contacts and calendar from Palm to iPhone...
how do i transfer my calendar and contacts from my palm pilot to iCal and iPhone?
Transferring Contacts from Palm Pilot to iPod
What software should I use to transfer contacts from my Palm Pilot Tungsten T2 to a ipod Touch or iphone
Add Your Solution
Attach a document to mail on iPhone.
I receive my emails just fine. But let's say (example): Tom emails me, I get notified of the email, I want to...
my iphone is neither charging totaly dead blank...
my iphone3g is neither charging(with wall charger or USB) nor syncing with itunes.i tried all possibilities like...
IPhone is dead, screen stays black nothing works...
IPhone is dead, screen stays black nothing works when trying to rest it, pluged into the charger does nothing, all this...
why can't i downloand apps on my iPhone A1241
It's an 8GB - model number A1241.
Fix-O-Meter
72,735
72,735 people viewed this problem
- 120 people found this problem to be helpful.
- 1 person is following this problem
Top Apple PDA Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
