Question about Sony Ericsson w580i Cellular Phone
Phone get switched off automatically when battery is low and the speaker works for sometime and sometime not!!
    Problem Solver:
  • 3 Answers
Software upgraded then problem salve.If does not salve this problem after software then giving next salution .
Posted on Jan 30, 2009
Hey I have an hdmx jam xt extreme wireless Bluetooth speaker & after a few seconds after I have paired with mine or a friends phone the music will stop playing, this sometimes doesn't happen if the volume...
To me it looks as if the battery is not charged ok. I'm not sure if you can monitor the battery voltage, but if you could, and you saw the voltage drop bellow a certain voltage and the speaker stopped there, and you could repeat this that would be the case. But perhaps you just charge the battery and discharge it a few times, before you panic. Some batteries only start working with full power after a few charges.
Jun 23, 2014 | Radio Communications
No sound from speaker but through ear piece I get sound.
Many devices will automatically switch off the large speaker when ear phones are plugged into them. Also there may be a switch or button or prompt on your radio to switch between regular speaker and ear phone jack. Look for that first.
Try connecting and disconnection ear phones while listening to a station and see if the problem is intermittent. If is works sometimes but not every time then it is most likely an internal connection.
You will have to access the inside of the radio to investigate further. Connect a working external music or sound source with speaker wire to the terminals inside the radio that connect to the radio's speaker. If the radio's speaker works with the external sound source then you know it is a bad connection inside your radio. If the radio's speaker does not work with the external sound source then it is most likely a faulty radio speaker. Look closely for a broken solder point or broken/disconnected wire.
Sep 10, 2013 | Eton E100 SW/FM/AM Radio
I am purchased this handset on 2009. After 1 yr the battery will show low battery, after charging 1hrs. pls assistance give me. regards..... AJILAL
If possible do full discharge and let it switched off automatically and then put your phone in charging, do not switched it on while charging.
initially do dis 3-4 in a week after do 1 time a week, it will improve your battery strength.
Do reply how does it work. Thank you.
Apr 21, 2011 | Samsung SGH-L700 Cell Phone
Head light problems sometimes they will not shut off sometimes they (low beams) come on by themself high beam will not shut off
Are you sure there not running in daytime running light, when you think high beams are on
Also, there is sensor on the dash, usally on the speaker grate, that senses night and day. In the daytime your headlights will automatically come on when your car is in drive, and be on the high beam bulb, but dimmer than regular. At night, or in low light conditions, your lights will automatically switch from daytime lights to regular low beams. And yes, even when your switch on the dashis turned off, your lights work automatically.
To turn of the auto setting, just push the override button for your dome light, in and out 3 times, you should hear a chime, and your lights should shut off. This setting resets everytime you shut your vehicle off. Or to turn the auto setting back on, push the over ride button 3 more times.
Apr 15, 2011 | 2002 Chevrolet TrailBlazer
Trying to drive this pair of speakers. Do you need to have batteries in them? do you have drivers or are they plug and play? If they need drivers can you send them in an email?
What manufacturer of speakers? What model-number?
Most speakers do _NOT_ have any "plug-and-play" capability -- they simply are electro-mechanical devices (amplifier, analog controls).
The amplifier needs power, either batteries, or an AC adapter, to convert the low-level outputs from the sound-card to bigger signals -- enough to move the speaker-cones to push air around, to make sound-waves.
Mar 18, 2011 | Computers & Internet
Automatically switched off
hi there,
please try to change you battery in a new one it is one reason why mobile sometimes shutting off by it self because the battery are not working properly evven you charge it always be drain in a few minutes.
if you already chnage the battery and still experiencing to shut off by it self..you need to go to a mobile technician because you have a problem in you power signal.
Hope i gave an anwser to your question.
please don't forget to rate me....
thanks,
Feb 17, 2009 | Nokia N70 Cellular Phone
Set hangs
hey if it automatically turns on if you put the battery that only means that the switch is stuck..
Jan 26, 2008 | Nokia 6300 Cellular Phone
GE Model 2-9315A
buy a new phone. it is a very cheap phone and not worth the time and effert that you waste on it life is to short. phone well worth the money . I own the same model and it works great and cost only $5 at wally mart.
Nov 06, 2007 | Lands Phones
No LCD Display since battery low and phone switched off!
Try to remove the battery for 10 minutes and plug it back in if fully charged. Sometimes the battery just gets tired and needs a new replacement. Try to unplug it first like I said.
Oct 26, 2007 | Lands Phones
Feedback noise in speakers and Woofer.
hi wfj1310,
that feedback comes from the distance between the mic and the speakers only. Low the record level from the mic and make the distance bigger.
it makes feedback with any speaker, not only with woofer :-/
complements
Oct 25, 2007 | Audio Players & Recorders
Sony Ericsson w580i Cellular Phone Logo
51 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
