Question about IBM Wheelwriter 30 Typewriter
Paper doesn't load properly in typewriter
I have an IDM Personal Wheelwriter 2 by Lexmark that I inherited from another office and of course no manual came with it. When I try to load paper into it, it feeds in sideways. The left side gets stuck on something. I have tried to to pull a piece of paper back and forth in between the platen and hope to dislodge whatever it is, but nothing comes out. Any suggestions?
  • IBM Master
  • 5,568 Answers
The platen shouldn't be too hard to remove; what you describe could be caused by the residue of labels which can be removed by lighter fluid or pure alcohol.
If removing it appears too difficult, try putting a broad stripe of one of the above across the width of the paper and then try again moving it side-to-side.
Posted on Jan 29, 2009
How do you save a document to memory and re-type from there? Is there a re-print button?
If you do not have your instruction book, go to lexmark site and search for it, can usually download a copy, so you will allways have a reference.
Jul 29, 2014 | IBM Lexmark Personal Wheelwriter 2...
Wheelwriter 2 correction ribbon lift adjustment nost high enough
Check that the lift off is properly attached to the ribbon and ribbon is installed properly, If the liittle tabs on the L/O cassette are broken you can use a piece of tape to hold them together.
DickyO
Apr 10, 2013 | IBM Lexmark Personal Wheelwriter 2...
I have a Lexmark 1000 Personal Wheelwriter and the daisy wheel does not easily slide into place. It then just keeps turning until the machine beeps and it stops. Will not type of course. Is there a...
No, the printwheels are the same for all Wheelwriters. Make sure the letters face the roller when you put it in (pull the print hammer assy back and check for paper clips, ribbon pieces, etc. first).
Jan 02, 2011 | Lexmark Wheelwriter 1500 Typewriter
I have an IMP Personal Wheelwriter 2 by Lexmark, my assistant moved it yesterday and now I have blinking green lights on the line spacing #'s. Please help
First check to be sure the printwheel is properly installed, then try turning it on while moving the flat keyboard connectors, if this starts it see my tip under WW1000.
DickyO
Oct 27, 2009 | Lexmark Wheelwriter 15 Series II...
IBM personal Wheelwriter 2 margins not clearing
Return to the L. margin, touch the mar rel key top key on L. of the keyboard, backspace to location where you want the L. margin, touch the L. mar key. Put some WD40 on the silver shaft that the carrier slides on.
DickyO
Jun 24, 2009 | Lexmark Wheelwriter 5 Series II Typewriter
Roxanne;
I an very knowlegeable about wheelwriters, I will be in the office today until 5:00 pm edt you can call at 216-241-0027.
DicktO
Mar 11, 2009 | Lexmark Wheelwriter 3 Typewriter
IBM personal wheelwriter 2 memory
I have a IBM Personal Wheelwriter 2 by Lexmark and when you turn it on it beeps and then the single and double space lines light up and stay on but the it will do nothing else. (It's like it is locked up
Mar 25, 2008 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 30 Typewriter Logo
227 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
