Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Connecting Vostro 1400 to Sony Bravia BR6?
I've tried connecting an RGB cable to both (other option seems to be an s-video connection from Dell - 7 pin to 4 pin). The tv does not recognize the connection. The computer does not display on the tv. The tv gives a message that there is no connection I select the pc symbol on the tv menu and choose the cable connection. I have tried rebooting the computer to no avail. What am I doing wrong? What do I need to do? My computer is using an NVIDIA GeForce 8400M card. It's set for 1280x800 with a 60 HZ refresh rate. Will this match the 1280X768 listed for the tv? I want to be able to show photos (which tv says it can do and I can do from flash drive but it's slow) and to see how it looks as a secondary monitor - mostly photos are important right now. Thanks.
    Genius:
  • Sony Master
  • 1,689 Answers
To properly drive your TV set, your computer will have to be able to supply 1366 x 768 with a 60 Hz refresh rate.
A resolution of 1280 X 800 is high. LCD and Plasma sets are very critical for the maximum resolution. You can go lower but not higher. If a lower than native resolution is used there may be some aspect ratio distortion, and the picture quality will be degraded.
There is a spec list at the link below:
bravia
-kdl-v40xbr1/4507-6482_7-31470102.html?tag=mncol;psum">http://reviews.cnet.com/flat-panel-tvs/sony-bravia-kdl-v40xbr1/4507-6482_7-31470102.html?tag=mncol;psum
Jerry G.
Posted on Jan 31, 2009
Connecting Sony Bravia TV to Dell Dimension 5150
Have you selected the PC setting on your TV? and set the resolution on your computer graphics to one that is relevant and usable by your TV.
Aug 21, 2013 | Dell Computers & Internet
Connecting my Dell Vostro 1400 to a Samsung S24B350H monitor
If the monitor has several video connections then you need to go into the monitor's settings and select the correct video input.
Mar 21, 2013 | Dell Vostro 1400 Notebook
I've tried connecting a Sony DVD player to my TV using Pb Pr V cables. I get a picture, but no sound.
The cable u are using it is the S-video cable?Yes,this cable dosen't support audio.Must used a RCA component cable like R,W cable connected between the tv and the DVD player to get sound.
Mar 14, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How can i connect my pc to sony bravia kdl-40ex403
Things You'll Need:
  • 15 pin RGB cable
  • Audio cable
Step 1
Connect the RGB cable to the Video Out jack on your computer.
  • Step 2 Plug the other end of the RGB cable into the RGB jack under PC In on the back of the television.
  • Step 3 Hook up one end of the audio cord to the Audio Out jack on the computer and plug the other end into the Audio jack under PC In on the back of the television.
  • Step 4 Turn on the television and press the "Input" button on the television or the television remote control. A list of input options will appear on the screen.
  • Step 5 Highlight "PC" using the up and down arrow buttons and press the "+" button to choose the computer input. The television will display whatever is on your computer.
  • May 01, 2010 | Lenovo 3000 N500 Notebook
    How do i connect a sony bravia tv to a sony dvd
    you can connect two diffent ways with your bravia lcd tv one is videu out connection from dvd &put the cable in to video in to tv other way is rgb connection there is three color sockets in your dvd player & same as your lcd tv so connect with color wise & switch tv to component
    Feb 06, 2010 | Sony DVP-NS575P DVD Player
    My sony bravia has no audio when used as cable tv
    Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
    Nov 08, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
    Connects at 54.0 mpbs instead of 108.0 mpbs
    Try using a cable.If it works problem could be with the wireless.
    Sep 10, 2009 | Dell Vostro 1400 Notebook
    No signal sony bravia to dell laptop
    Most laptops have a combination of buttons you have to press on the keyboard to get it to output on the monitor output. Try pressing the FUNCTION KEY or FUNC/FN key usually found in the bottom left hand side of the keyboard. Keep that button held down while press one of the number keys. Usually the number key will have a picture of a TV screen on it. Might be number 8 or 9. Press both keys at the same time a you can switch between laptop screen, Sony LCD or you can have both..
    Mar 20, 2009 | Sony Televison & Video
    How do I what whats on my computer on my tv
    your question is not clear
    but I think u want to watch screen of Computer in sony bravia LCD/So u can better/use a video card for ur computer/Ex:-e-GeForce 6200 256 MB DDR2 PCI Graphics Card or Stealth Radeon 9250 256 MB DDR PCI Cinematic 2D/3D Graphics Card/Try these video cards to connect ur computer to sony tv/Try it out or else u can reply back
    Feb 25, 2009 | Dell Dimension 2400 PC Desktop
    Laptop connection to tv
    dear sir.
    u have to ser yr tv resultion and do as same as tv in to yr laptop after that it's a tool given by drviers chek that this avalable in display propeties>setting>advance>adapter.. here u have all kind of setting avalable...:)
    Thanks
    please vote
    jo_chinmay
    Nov 17, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
    Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
    359 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
