Question about Dewalt DC2PAKCA Heavy Duty Xrp 18V Cordless Hammerdrill / Reciprocating Saw Combo Kit
Recip wont take blades
I think my recip is gummed up with debris. So when i try to use the quick release to put a new blade in the piece that holds the blade secure wont open to put a new blade in. Is there a way to take off the protective rubber by the locking mechanism to clean it?
  • 2,176 Answers
I would try using compressed air first to blow out the lock mechanism and then use something like WD-40 and spray the area and move the lock and spray again, this usually will free up the lock. If not please furnish me the model and brand and I will look at a breakdown and see what I can come up with.
Posted on Jan 29, 2009
Broken reciprocating saw blade stuck in saw
Hello, I found a very quick and easy solution to this. Pulling the blade release and shaking, and taking the saw apart, did not work. What worked instead was to simply turn the saw on while pulling the blade release at the same time - when I did that, the piece of stuck saw blade came shooting out. Please be VERY CAREFUL while doing this, making sure you are wearing eye protection and pointing the saw away from others, so that no one gets hurt by the ejecting blade piece. I would also suggest knocking and shaking the saw while holding the blade release before you try this, as another poster suggested, because if the blade piece is big enough it might come out this way, or at least it may help loosen it so that it will easily eject outward when you turn the saw on. Good luck!
Jun 26, 2012 | Ryobi P510 18V Cordless One Variable Speed...
The blades come out
The piece that holds the blade in is held in place by a spring that sometimes breaks. eReplacementparts.com has a diagram and sells the springs for 78 cents.
Apr 25, 2012 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
I'm unable to remove the blade from the quick change something won't release the blade model 6521-21
what you can try is to unplug tool and spray something like WD-40 on the collar mechanism and usually it is simpler for this to remove the pivot shoe and turn the collar and release until you can get full rotation and pull the blade out. There might be some dirt in the release mechanism not allowing the blad/collar to release. This is about the only way without having to remove the assembly. Let me know if you need more assistance
Mar 11, 2011 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Milwaulkee sawzall quick release wont release.Cam turns ok but pin is holding blade.Tried prying blade out w/vise grips-no luck
try using WD-40 first to loosen up pin and if not you might have to replace the quick lock assembly. ot a tough job about 10 minutes or less.
Jan 17, 2011 | Milwaukee Tool 10 Amp Sawzall Plus with...
Blade stuck in keyless chuck on sawzall. pin or spring must be broken. Any suggestions on how to get the blade out
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Jul 14, 2010 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
I am trying to change the blade on my Bosch PHO1 planer. I have taken out the two grub screws holding it but it won't release - any ideas?
If the blades are hard to remove, you will have to remove the blade clamp completely in order to clean everything up. Your blades are probably gummed up from use. If you have a small torch available, you may want to try heating it up a little, this will release the blade (if you are using HSS blades). Be carefull not to melt any plastic in the surrounding areas. If you are using the micro carbide blades you should be able to press the blades out from the side using a scrap piece of wood without removing the screws (just loosen). Use mineral spirits or lacquer thinner or alcohol to clean all surfaces so your new blades will seat properly.
Oct 09, 2009 | Bosch 1594K 3 1/4" X 3/32" Planer Kit with...
I have a Milwaukee sawzall 6509-22 with a quick loc cam. Blade went in fine, but now the saw wont release the blade to come out. How do I fix this problem. Note: locking cam is turning fine
K you used the saw after inserting blade?? If so couple ideas, hold collar open and put saw blade in a vise and try pulling back on saw, or you can remove the quik lok cam and release it that way, its not that hard, but I would try vise first. Let me know
Jul 29, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Stuck blade
I looked for a picture of this saw -- couldn't find one. When you wrote that you put the blade down on a 2x4 that sounds like a chop saw. In which case the balde is attached to the motor shaft.
A torch is kinda extreme, but if you do it safely & quickly it might work. If the blade is on the motor shaft, you don't want too much heat to get into the motor.
You don't want to heat the blade. Heat the nut only -- the nut will expand more than the shaft and perhaps break loose. I wouldn't heat it more than 20-30 seconds and make sure the flame is directly on the nut. Also make sure all flammable stuff is out of the way (like sawdust).
I wouldn't expect the heating to allow you take it off by hand -- you'll probably have to try all the brute force measures again -- and remember the left hand threads.
Apr 21, 2009 | Saws
Blade lock on Craftsman 10 amp recip
The guide foot comes completely out by wiggling and pulling a little harder than you would think. It is held in place by friction in addition to the two screws. Once the guide foot is removed, remove the front metal support piece by prying it out of the groove in the rubber boot. You can then access the pin and blade release lever. Make sure the return spring is in place on the rear side of the blade lock latch.
Apr 11, 2009 | Craftsman 8.0 amp Reciprocating Saw
Dewalt DC2PAKCA Heavy Duty Xrp 18V Cordless Hammerdrill / Reciprocating Saw Combo Kit Logo
230 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Tyler Craig
Tyler Craig
Level 1 Expert
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
