Question about Philips HDD100 MP3 Player
Hard Disk problem
What am I suppose to do with the Philips HDD100 if i can't turn it on? I can use it when connected but I'm stuck when I disconnect it! What should I do, in theis case? please help!
I think you battery might have died.
Sounds exactly like the problem I had when mine died.
Posted on Mar 01, 2009
WONT START
hi, turn off pc and disconnect from power.Access the hard disk by flipping the laptop over and openning the four screws at each corner.As soon as you open,the hard disk will slide out.Disconnect hard disk and remove the CMOS battery.Refix them again, connect power and start the pc. Hope this helps.Thanks!
Sep 30, 2011 | Toshiba Computers & Internet
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
How to interface the hard disk with another computer for checking problem with which software?
Welcome to FixYa!
i hope there isn't any problem in your hard disk .
lets say if you have
hard drive 1 with problem
hard drive 2 without problem .
actually if you boot from hard drive 2 and the hard disk1 that you have trouble in , then you cant identify the problem.but only read the data from hard disk 1
O/S faults can only be identified while you are in the O/S. so my suggestion is
please tell us that what do you want to do with your hard disk. and whats the problem
Post a comment here and ill let you know .!
Apr 23, 2011 | Fujitsu (MHF2043AT) 4.3 GB ATA-33 Hard...
My aspire l310 won't boot. It keeps telling me media cable test failure and disk boot failure. Help daniel
sounds like hard disk related. turn it off and disconnect the power cord, remove and reconnect both the power and data cables to the hard disk, disconnect any external USB storage and remove any floppy disk, if any. If you get the same result, try to connect the har disk using different power & data cables (IDE/SATA), and test it on another SATA channel if available. If same error, you may need to reformat the hard disk and reinstall WIndows, or you may have to get a new Hard Disk if it fails even when tried on another computer.
Aug 31, 2010 | Computers & Internet
External Hard Disk problem to connect
Try connecting in safe mode with networking and then check if it doesn't disconnects then scan your system with mcafee 8.5i anti virus.
Perform a checkdisk on your usb drive
Please rate this fixya
Jan 09, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
It Bricked itself
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Aug 13, 2008 | Philips GoGear HDD6330 MP3 Player
HDD 100 - files can be deleted but not added.
There are a few different possibilities.
1)Your subscription to your digital music service such as Napster, etc has expired. Sorry - unless you renew your subscription, you will not be able to play these songs again.
2) Your songs have DRM-encryption on them. To check and see, right click on an individual song name in Windows Media Player, and click on "License" or "Digital Rights"; if the affected songs have DRM encryption, then get DRM-removal software.
3) Your songs do NOT have DRM-encryption on them. In this instance, follow the procedure for item#2, except click on the link in the License or digital Rights tab that says "acquire license" (make sure you are connected to the internet first).
Jun 26, 2007 | Philips HDD100 MP3 Player
HDD 100/17 mp3
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Apr 26, 2007 | Philips HDD100 MP3 Player
Philips HDD082/17
Try a soft reset by holding the play/pause and the volume up button for a couple of seconds.
Oct 07, 2006 | Philips HDD082 MP3 Player
Wont Turn On
-Tha Mp3 Doctor
Aug 14, 2006 | Philips HDD100 MP3 Player
Philips HDD100 MP3 Player Logo
106 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
