Question about Lexmark X8350 All-In-One InkJet Printer
Language on Printer Window Screen
My 2 year old, constantly touches the buttons, and he switched it to something i guess looks Russian??? And because i can't translate, i don't know which option to scroll to get it back.
Here's a possibility:
Hit the menu button, scroll down to the 3rd option (Device Defaults)
Hit the "check" mark
Scroll down once to language
Hit the right (or left) arrows until you see English
Good Luck!
Posted on Feb 12, 2009
NEC TV - How to change language of menu
I just bought an NEC FS-5160 from a local opportunity store last Friday (July 2, 2010) with the same problem. After a few minutes of fiddling I found the solution:
1. Press 'Menu' button. You will see 'Menu' written in Russian. To the right you will see a number '1' above the the word 'TV' or 'Video'. This is 'Menu 1' or screen 1.
2. Press ONLY the 'Menu' button and the arrow on the left will scroll down. On the fourth press the '1' referred to above will change to a '2' for 'Menu 2' or screen 2.
3. Continue to slowly press the 'Menu' button until 'Memu 3' or screen 3 appears.
4. Press the 'Menu' button twice more and then use the first channel changing button to change the language from Russian to English.
Apr 02, 2010 | Grundig GF70-600 TV
The language coming up looks like Russian, how do i get it back to english?
Go into the tools menu and find "language" and reset it although may be difficult if everything is in Russian. However there is a "restore" on screen button that can also get you back to where you want to be.
Nov 06, 2009 | Garmin nuvi 350 GPS Receiver
How do I change my HP 2600n Language back to English
A. To change the display language back to English, please perform the following steps:
1. Press the right arrow 2 times, press the OK button (you should be in the System Setup menu).
2. Press the OK button again (you should be in Language).
3. Press the right arrow until you see something that may be English, press OK button. The menu is a continuous loop, so if you miss it the first time the option will return.
May 22, 2009 | HP Color LaserJet 2600n Printer
Htc touch only with Russian even after i switch to English
pls try to hard reset the device pls backup ur data b4 doing it and take out ur memory card also and see if it gives u screen to select the language to english , other wise u need english rom from www.htc.com just go and download an updated rom from the site and do as directed
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest English Rom update download and update backup ur data first
Feb 22, 2009 | HTC Touch P3450 Smartphone
Wacs 7000 IS IN DIFFERENT LANGUAGE I CANT CHANGE IT
I had the same issue and I couldn't find an answer anywhere. however I had a mess and found if i do the following it goes to reset and it automatically transferred to English.
1, disconnect the station and centre from the power supply ( ie switch the wall socket off)
2, press the ok button on the units, ( do these seperately unless you have 3 hands) keeping your finger on the button and switch the wall socket back on, (keep your finger on the ok button until it says resetting system (or something along those lines)
hopefully it should reset to english, please let me know how you get on
Dec 27, 2008 | Philips WACS700 Shelf System
LANGUAGE SETTINGS
Well, i fixed it the long way- while the display is in Russian, I spent 2 hours scheming through every single menu item until eventually I saw the word "English", then I hit the <enter> button- and voila! The printer re-booted itself back to normal, and everyones happy. Not quite a tech solution but least it worked..
Nov 03, 2008 | HP LaserJet 2840 Printer
HP printer needs to switch back to english
Try a cold reset..power the machine off. While its powering on hold the check /go button down when you see the memory counting when lights are all lit up let go.
Aug 26, 2008 | HP Color LaserJet 2600n Printer
Nuvi 200W series: need language change
If you don't know foreing language displayed try follow that to change it to English:
- touch Tool icon
- touch upper left icon
- touch Down arrow 1 time
- touch upper ( of four) line
You'll find 3 buttons on the right Upper/Middle/Lower and 2 on the bottom
Depress Middle one, then using Up/Down arrows select *English and OK
Jun 18, 2008 | Garmin nuvi 200W GPS
HP Laserjet 3030 printer/scanner/fax Language has
How can i change HP laser jet 3030 printer's language?
Mar 17, 2008 | HP LaserJet 3030 All-In-One Printer
Language setting
Try this: 1. unplug all cables from back of unit (turn power off as well) 2. while the printer is off hold down the * and 5 3. while holding them turn printer on 4. continue to hold buttons until display reads 'Permanent Storage Init' 5. then release buttons 6. at the end of reset it will ask you to select language and location, just press enter then 1 to confirm Hope that works!! Ed PS. You could have picked an easier language!!!
Jun 12, 2007 | HP LaserJet 3055 All-In-One Printer
Lexmark X8350 All-In-One InkJet Printer Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
