Question about Hotpoint WMA35 Front Load Washer
I have the hotpoint wt741 and is currently saying test
This is for all programmes and it is also on some occasions saying f10
  • Hotpoint Master
  • 3,463 Answers
The error code f10 is indicating a problem with the pressure switch or water level switch as it is sometimes called,
There a few things to check.
First, remove lower rear cover of washer, locate and remove the large black hose that goes onto the tub, remove and clean filter in there,
detach plastic pressure chamber attacthed to hose, and clean if req'd, remove small plastic hose and blow down it, you should hear a click if you listen carefully, this is the pressure switch operating, if you hear no click, then make sure the hose is not blocked, if clear, and you hear no click, then you probably have faulty switch.
If all these points are o/k. then the problem should be solved.
PLease leave a fixya rating if you consider my solution appropiate to your problem.
Thanks.
Posted on Jan 30, 2009
Wt741 machines drum
It is possible the motor start capacitor has failed. Unless you know how to test it, call a service person.
Oct 19, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741 f10 fault code
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked / blocked.
Apr 10, 2012 | Hotpoint Washing Machines
I have a hotpoint ultima WT741 flashing F-10 can you tell me the problem please
F10 is a pressure switch not sensing error. Basically its a filling problem.
What you need to do is make sure the fill hose isn't kinked up at the back stopping it from filling fast enough.
If the hose is OK then take off the fill hose and aim it into a bucket and turn the water tap on. Then from there see what the water pressure is like there.
If its weak then you need the water pressure sorting out.
If the pressure is fine then you will need a multimeter and test the water valves on top and see if any of them are faulty.
But the F10 error code is a filling issue.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 01, 2011 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima WT741 is stuck in test mode. Can anyone tell me how to cancel. Carol
unplug for 40 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 19, 2009 | Washing Machines
Hotpopint Washing Machine WT741 flashing F-12
Resolved the problem.
Switched off the power to the machine. hit the on /off button and the f-12 error code disappeared .
On reappling the power to the machine the orignial programme continued to completionj
Jan 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WT741
turn the machine on while pressing the on annd stat buttons at the same time until dOFF appears.
Apr 20, 2008 | Hotpoint Aquarius WD640 Front Load...
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Hotpoint WMA35 Front Load Washer Logo
164 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
