Question about Xerox 212 Laser Printer
Copier 212 error code U4
Copier was moved...has not been used...when turned on it displays error code U4
    President:
  • 2,072 Answers
That is a fuser code. May be a bad heat rod or just need reset.
Here is how to reset it.
Enter diagnostics, Here is the procedure.
To enter diagnostics:
Hold down ‘0’ while turning on the Power the console will light up. Press ‘Stop/Clear’, the lights will shut off & --- will appear in the display Wait 30 seconds for the optics to complete a self-test before you enter any diagnostic test codes. Never turn off the power before the optics stop moving (or you’ll get a U2 code & possibly some unpleasant noises from the Scan Drive Motor).
Next setp is to use the code to clear the U$ code.
*To clear a fuser code:(401)
Enter diagnostics, wait 30 seconds for the optics to initialize, enter ‘401’ followed by ‘Print’, then shut down the power & wait 10 seconds before switching power back on.
That will normally clear that problem. Often times when a machine has set for a long time they wont warm up right and pop that code.
Another thing, if you can get the machine to warm up and come ot ready then it pops up a U4. Open that right side door. You will see this silver, looks like a small saw blade. It should be silver, but it will have a lot of ink built up on it, take a soft brush and clean it with that.
Let me know, if hte code 401 doesnt clear it, then the heat rod would have to be replaced. If that happens please let me know and we will procede from there.
Posted on Jan 30, 2009
My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Mar 18, 2011 | Xerox WorkCentre Pro 423 Copier
Copier is a 214 and shows U4 code
turn on power while holding down "0", press "stop/clear" and wait 30 seconds for optics to finish initializing, then enter "401" then "print", shut off machine, wait 10 seconds and turn back on. code should now be cleared.
Sep 06, 2009 | Xerox 212 Laser Printer
Xerox 212 copier
It melted in the fuser and has over heated.
You will need to replace the fuser. Google a business called The parts drop, call and ask for Britt.
Dec 22, 2008 | Xerox 212 Laser Printer
What is about Error 212 ?
E212 Lens sensor or motor problem
remove the glass, check to see if sensor is out of place. turn off copier move lens by hand and turn on does lens move, yes motor is most likely O.K.
does it stop at the sensor and give code? yes replace ( or swap sensor) doesa it still do it? No? replace bad sensor
Oct 29, 2008 | Canon NP 6050 Copier
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Oct 03, 2008 | Office Equipment & Supplies
Xerox212
that error is for the FUSER unit
Sep 30, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Jan 02, 2008 | Panasonic DP-150A Copier
Xerox 212 copier
Most likely replace the fuser.
And be sure you use transparencies marked for copiers only.
The U4 is an over heat because the tranaparency stuck between the heat roll and the thermistor. Causing the fuser to stay on and blow the overheat.
Oct 13, 2007 | Office Equipment & Supplies
Xerox 212 Laser Printer Logo
457 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
