Question about Kenmore 75962 Gas Dryer
Not heatig up just cold air
Hello I have a kenmore electric dryer that is only blowing out cold air and not getting hot.What can I do to fix the problem?is it going to cost alot of money?
  • 5,911 Answers
If the dryer is blowing air, then I'm assuming the drum is turning. If this is the case, the following link explains how to diagnose and correct an electric dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
This is an ELECTRIC dryer, correct? I ask, because you posted this under GAS dryers. Pay particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by poor air flow due to clogs in the vent ducting. Cleaning the lint trap is not enough in most cases. You need to also check the ducting and dryer interior from time to time. Clogs in the ducting actually forces the dryer to work harder and causes the heating circuits to overheat to the point of failure. Not to mention...this can be a fire hazard! If you cannot remember the last time the dryer ducting was inspected or cleaned, now would be a good time to do so. Leaving a dryer in a clogged condition will cause premature failure of any parts you may replace.
To answer your question, "No", this generally does not cost a lot of money. All the heating circuit parts, combined, would cost roughly $100 or less (if you had to replace everything). This is also a fairly simple repair that the average do-it-yourselfer can accomplish on their own.
Read through the link thoroughly and let me know if you have questions. If you require additional assistance, please let me know before you rate the solution. I hope this helps you.
PS If this was intended to address a problem with a GAS dryer, please let me know so I can correct the diagnosis for you.
Posted on Jan 29, 2009
    President:
  • 1,314 Answers
No replace the element or the thermal limiter also called the thermal fuze
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
OUR KENMORE DRYER BLOWS OUT COLD AIR
It's most likely a thermal fuse if it's a gas dryer. very easy to install. If your dryer is electric, it's either the thermal cut-off or the heating element itself. If you need help with anything, please feel free to e-mail me. good luck :)
Jul 06, 2009 | Kenmore Dryers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Dryer will run for a second and sound three beeps and stops.
Sounds like the door switch has gone bad., but your description is confusing.
First, it takes a few minutes for you to feel the air blowing hot, particularly when the dryer is in a cold garage. The heating elements have to heat up the mass of the metal, and any clothes in the dryer.
The timer design is such that it can not speed up (the motor inside wont start running faster, due to it's electrical design.).
I am suspect that the door switch has failed for some reason, because reading between the lines, I think you are saying when you release the Start button, the dryer quits operating. If the door switch is bad, then it will cause that condition to happen.
Jan 18, 2009 | Kenmore 62802 Electric Dryer
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Dryer blows cold air but no heat
The heating element is in the back of the dryer. Sometimes there is a small access panel that will allow you to check the terminals to the heating element. You will need an ohm meter or multimeter to check.
Jan 02, 2009 | Kenmore 62802 Electric Dryer
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer 110.66812690
kenmore dryer 110.66812690 won't get hot blowing out cold air.
Jan 01, 2008 | Dryers
KENMORE DRYER
Electric or gas?
Sep 13, 2007 | Dryers
Kenmore 75962 Gas Dryer Logo
193 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
