Question about Clarion DXZ375MP CD Player
Clarion DXZ785USB - Connecting Fused Lines
On the wiring harness for the head unit there are two yellow lines. One is labeled "Yellow Wire Memory back-up lead" which has a 15A fuse. A second "Yellow Wire Bus power lead" has a 3A fuse. In both cases the instructions say 'connect directly to battery'.
My confusion is as follows.
1. Do I really need to connect these directly to the battery?
2.If so to what terminal?
  • 67 Answers
You will definitely need to connect the Yellow Wire Memory Back-Up Lead, since this is the connection from the radio to the battery that stores the time and your presets. If it is not hooked up, you can use the radio, but all your settings will return to default once you turn off the car. The Yellow Wire Bus Power Lead sounds like it would be for powering an auxiliary unit like a Sat Radio or HD Radio add-on. You will not need to connect this unless you have an add-on such as one of these.
Posted on Jan 29, 2009
    Problem Solver:
  • 13 Answers
You do not need to connect it directly to the battery. There should be a yellow wire on the harness that you can connect both of those to.
Posted on Sep 07, 2009
My 03 elantra gt radio resets when i turn off the car
Ignore the color of the car's wiring harness(every manufacturer has a unique color code system).The memory wire needs a constant 12v battery connection to keep the presets.One of the factory radio's feeds will be a 12v feed like this.The best tool for figuring this out is a basic 12 volt test light.
Jun 13, 2012 | Kenwood Car Audio & Video
Need to know what wire colours r what on the harness of a Clarion DXZ635MP CD player lost manual
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
May 27, 2010 | Clarion DXZ545MP CD Player
I dont have a diagram for my clarion drb4475 wires. can you tell me what each wire is for?
Typical Head Unit Wire Harness Function Typical Wire Colors Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Blackedd1c80.gif
Mar 27, 2010 | Clarion DRB4475
I installed a clarion cd player now cd plat doesn't shut off
THe red wire is to be connected to power from the ignition.Meaning this wire should only be hot, when the ignition is on..
Sep 07, 2009 | Clarion DB538RMP CD Player
We had a clarion reciever with tape deck in our boat and found another clarion reciever with two new speakers and two good 1996 speakers which had not weathered. The instalation was difficult but the...
As long as you have connected the ground(black) try adding one wire at a time to the live(red). If possible try connection each wire one at a time to the power line and then both together. If nothing has blown(fuses) and the unit starts working then you can try by trial & error method the remaining wires. You should be able to figure out which wire is required and if there are any extra wires like cellular phone(mute) and then decide whether to connect them or keep them open.....sodeep
Jul 27, 2009 | Clarion DB245 CD Player
Clarion marine stereo M2455
Don't worry about the brown wires. They are for telephone mute.
The yellow is Memory (constant 12 volt, so battery is fine), but the red should go to a 12 volt source that turns on and off with the key.
Aug 05, 2008 | Clarion DB245 CD Player
Someone gave me a Pioneer DEH-2700 head unit and didn't have any of the manuals. I have a 2007 Chevy Cobalt How to I install this unit into my car. I don't know which wires go to what or anything
the easiest way to solve this issue is to buy a wire harness for your car this will make the install alot easier. Its already color coded for your wires, so head out to your local installer or try best buy you might also need a stereo kit. Email me with questions on installs.
Jul 25, 2008 | Pioneer Car Audio & Video
Clarion DB245
You need to connect the YELLOW wire to +12VDC also.
The YELLOW wire is for the memory of the radio and it connected to constant power line.
Dec 21, 2007 | Clarion DB245 CD Player
Clarion radio wiring diagram
i have the same stero in my boat made 2004 it is easy red(hot) black (Ground) Orange (Illumination) (hot) the 2 fused yellow is bat direct (memory) blue w/white stripe (remote) solid blue (power attenna) the 2 white wires ft left speaker, 2 gray rt front, green left rear, purple rt rear, the single brown is for the changer i believe
May 28, 2007 | Clarion DXZ645MP CD Player
Clarion DXZ375MP CD Player Logo
663 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
