Question about GE JGBS04 Gas Kitchen Range
GE XL44 range model JGBS04 ignitor not working
One of the 2 ignitors on the stove-top burners does not spark. The other one works. Do I just need an ignitor? What is the P/N?
I know how to turn off the gas and am OK with mechanical things. Can I do this myself?
SOURCE: GE XL44 Gas Stove
This Randy again. I checked out the top of the stove as you suggested and found every thing to be ok. Where might the pilot light be located on this ge xl44? this unit is about 13 to14 years old.
Thanks for your help
Randy
Posted on Sep 18, 2008
MNTECH
  • 1543 Answers
SOURCE: JGBP33 BAKE IGNITOR
You did not post a complete model number, but this should help:
Take racks out of oven. Remove two screws at the very back of the oven bottom. Lift back side of bottom up and back a bit to remove oven floor. Remove flame spreader (one nut at center). ignitor is at the back left of burner, most likely a WB2X9154 (round style) ignitor. The entire burner can be removed rather easily at this point if you remove the two screws at the front and disconnect the ignitor wire (if you wish to have easier access to ignitor mounting screws.)
Posted on Nov 23, 2008
RescueTech
  • 145 Answers
SOURCE: Bake ignitor Location
Hi Kurt, welcome to FixYA!
In the diagram below, Part #28 is your ovwn ignitor. (See the red markings to highlight it)
It is located underneath the oven floor, and the floor should come out by removing the two screws located in the bottom rear of the oven cavity. Take out the racks, take out those two screws, and lift the oven bottom up from the rear, then disengage the front lip and lift it out. I hope this is helpful info and thanks for allowing us to be of service to you.
a16646a.jpg to you.
Posted on Dec 23, 2008
  • 18 Answers
SOURCE: Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
Posted on May 17, 2009
  • 23 Answers
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
Xl44 top burners light
There are a few things that can do this... First check the burner top to make sure the holes are not blocked. 2nd, Are the other ignitors sparking? If so then try rotating the slack in the burners left and right - this works sometimes. If not then try placing a screwdriver (you holding the handle only) and touch the burner and lean the screwdriver towards the ignitor... making the spark gap smaller. If you have used the ignition without a burner in place the ignition pack will short out inside it and there will not be a spark until the gap is very small. 3rd, are the ceramic part of the ignitors cracked at the base... take care when washing as they break easy if caught on the cloth. The ignition pack works in pairs so having one work suggests the pair of this one is something in the lead if there is no spark... A huge spillover causing a short or a bad earth... check the burners are firmly in place. There is more but too much detail to post here. Good luck
Jan 02, 2014 | Kitchen Ranges
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE Kitchen range XL44, stove top burners work fine, but oven won't light??? HELP please
Unplug the range.
Remove the oven racks.
remove the oven base pan.
remove the flame spreader pan.
remove the glow bar ignitor on the left hand side of the gas burner and replace it with a good ignitor.
Jan 25, 2010 | GE Kitchen Ranges
Jun 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Top works bottom doesn't
I have XL44 oven JGBP26. I replaced the glow ignitore on the oven but still will not glow. I carfully tested the current to the ignitore and showed 125 volts, I also tested the resistance on the control valve lead and to ignitore and showed 1100.
Dec 15, 2007 | GE JGBP28 Gas Kitchen Range
Ge xl44 I think pilot not lit. no more snap - snap and does not light
relace spark module if no snap snap from all burners.If one is just bad replace ignitor.
Nov 21, 2007 | Hotpoint RGB745 Gas Kitchen Range
Ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Oct 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGBS04 Gas Kitchen Range Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
