Question about Bose 3 2 1 Series I DVD Home Entertainment System , Retail System
Can only get black and white images when playing DVD's
I have a Bose 3·2·1? GS DVD home entertainment system and when playing dvd's can only get black and white pictures. I also have my sky (cable) tv set up with the system. I have tried doing what the troubleshooting in the manual suggests (to check the video connectors are solidly in place) anyone have any other ideas?
Check your settings - video format. It should be NTSC for USA standard. If it is set to European (PAL) it will be in black & white. Hope this helps.
Posted on Mar 17, 2009
  • 4 Answers
I have the same problem with my dvd player soon as you turn it on the screen to the machine is in black and white on the tv its not the dvd its something to do with the tv's ability to switch over to color try connecting it to a dvd recorder that solves the problem most the time the problem is not always the menu stting s inside the machine its self some machines dont have a settings feature to make it in color its most likely something very easy to do the way i mentioned above should help you a little
Posted on Jul 31, 2007
  • peter gray Jul 31, 2007
    if you need it to be in color the only way i know how is to connect it to my dvd recorder it seems to solve the problem like i said in my other post
    untill you find a easy fix for this it could be the scart leed but nope
    when i feel the need i will try other ways to solve this when i do i will post it here
2 Suggested Answers
SOURCE:
whitesox
  • 64 Answers
SOURCE: Black and White images Only
Go to the menu system and change your system from NTSC to PAL, or vice versa. Instructions for this are on p.39 of the manual.
Posted on Jul 27, 2007
Connecting a turntable to a Bose 3.2.1. Series II
Bose 321 GS Series II DVD Home Entertainment System is a newly redesigned, sleek media center that includes a DVD/CD player, AM/FM tuner and inputs for three additional sources. The 3 2 1 GS Series II system now has even greater ease of use and setup. The 3 2 1 GS Series II system is for customers who want the benefit of home theater sound but would prefer the simplicity of two visible speakers, a hideaway Acoustimass module and fewer wires so they don't need to run wires to the back of their room. Media center plays - DVD video (including progressive scan formats), AM/FM, CD, CD-R, CD-RW, digital 5.1, and MP3 files on CD AM/FM radio includes 20 presets, scan and seek Three audio inputs with both analog and digital coaxial jacks, and one optical digital audio input, provide greater setup flexibility Dimensions - media center, 31/6H x 133/4W x 99/10D (8.02 x 34.93 x 25.27 cm); speaker arrays, 21/2H x 51/2W x 41/8D (6.4 x 14.15 x 10.52 cm);module, 141/2H x 83/4W x 191/8D (36.7 x 22.2 x 48.5 cm) Weight in carton - 44 lbs (20 kg) One-year transferable limited warranty
and from the review
Audio-input connectivity is a bit more robust. You can connect three audio sources through analog or digital jacks. The system is compatible with MP3 CDs and can decode Dolby Digital and DTS surround soundtracks from DVDs and external sources.
Bose 3 2 1 GS Series II DVD system review
May 14, 2017 | Bose Audio Players & Recorders
Blew fuse bose 321
When a fuse turn black, you have a serious short inside. Repalcing the fuse will do nothing. For more information, please visit my website at audioserviceclinic.com. You may contact me directly through the website.
Feb 06, 2014 | Bose 3 2 1 GS Series II DVD Home...
How i sync a ilink box codes to a bose remote control sistem
I have the same problem but my remote is Bose Cinematic and in the list does not appear. Can somebody help.
Sep 21, 2013 | Bose 3 2 1 GS Series II DVD Home...
Bose 321 series wont play region 1 dvd
To convert Bose 3-2-1 GS Series 2 DVD system to Multi-Region playback
1. Press the Right button on your remote control
2. Press the Up button on your remote control
3. Press the Shuffle button on your remote control
4. Press the Stop button on your remote control
5. Press the Mute button on your remote control
6. The disc tray should eject twice to confirm the region change
7. Press the Standby button on your remote control to power off your machine
8. After one minute, press the Standby button on your remote control to power on.
Done!
Nov 29, 2010 | Bose 3 2 1 GS Series II DVD Home...
Dvd playing in black and white
problem is most likly in tv menu settings. display or picture and chang to color
Apr 25, 2010 | Bose 3·2·1 II System
Can someone tell me how the picture is when playing a dvd to a hdry set. I heard it's not very good. Thanks John
Did you mean : playing a normal dvd on a HD tv? ....It will be fine. Check your dvd menu to see if it can upscale. If your using a huge tv you will notice some grain...but hopefully your not sat 2ft away!
Aug 08, 2009 | Bose 3 2 1 GS Series II DVD Home...
Ipod nano connector for Bose 321 GS Series III
OK! The cheapeast and most simple way would for you is to get a 1/8th inch conector jack that adapts into red/white RCA jacks (it will have a couple feet of wire in between the jacks) plug the 1/8 inch adapter into the jack on I-POD and the RED/WHITE ends into the back of your systems aux inputs RED/WHITE! OR tape input ect! make sure I-POD is turned up! and you may have to adjust I pod eq to get the best sound out of system! (OH you can get this adatper at any radio shack or wall-mart!)
Please take a second and rate this response
THANK YOU!
Jan 19, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
Jul 27, 2007 | Bose 3 2 1 Series I DVD Home Entertainment...
Bose 3 2 1 Series I DVD Home Entertainment System , Retail System Logo
823 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
