Internet connction problm due 2proxy ser er
Bittorrent doesn't work in my hostel internet connection.i think there is a firewall in da server vich bard da torrent support.can any1 help me regarding dis so dat i can use torrent sites.i want 2download files thru bittorrnt.somebdy plzzz help me furder detail regarding my proxy address or port i'll give u ven u contact me either thru my yahoo id or gmail id(on gtalk) "sid8379@gmail.com".also tell me da software by which ican download files from torrent sites
    Problem Solver:
  • 16 Answers
  1. Get Azureus from azureus.sourceforge.net. (You need to have Java installed on your machine first.)
  2. Run and configure Azureus:
    • Skip any updates, because they rely on torrents.
    • Set your proficiency level to Intermediate, so you can change the encryption settings later.
  3. Go to Tools -> Options -> Connections -> Transport Encryption, and require encryption.
  4. Under Mode, set your proficiency to Beginner. (Beginner has all the options you'll ever need as a downloader.)
  5. Restart Azureus, and let it do any updates it deems necessary.
Posted on Feb 01, 2009
How to block torrent download in sonicwall tz190
BitTorrent is a torrent downloading client used to download
music, video and game files for free.
BitTorrent can really eat up bandwidth, which can be mighty
frustrating, especially if you're sharing a computer and an Internet connection
with someone who's using BitTorrent.
If he's not willing to stop using BitTorrent, there are a
few steps you can take to block this demanding program.
Switch your Internet service to an Internet service provider (ISP) that is
hostile to BitTorrent. RCN, for example, is known to block BitTorrent traffic.
Try blocking all ports from 6881 to 6999 on your system.
You must first add a port before you can block it. Click
"Control Panel" and then "Network and Internet
Connections."
Click "Firewall Settings," and select the
"Exceptions" tab.
Click the "Add Ports" button. Enter the port
number you want to block, and click "OK" to save your changes.
Navigate to the "General" tab in the "Windows
Firewall" section, and remove the check mark from the port you just
created.
That port is now blocked and cannot be used by BitTorrent.
Unfortunately, performing this procedure 118 times is
somewhat time consuming, but it is one of the few ways known to block
BitTorrent.
If someone is using BitTorrent on your computer, don't
allow him access to it.
If he's using BitTorrent on his own computer, you may have
to buy your own machine to avoid conflict.
If the Internet is slow on your computer because
he's downloading via BitTorrent on his own machine, consider using a public
Wi-Fi point such as a library or coffeehouse.
Nov 11, 2013 | SonicWALL TZ170 (01-ssc-5740) Firewall
Error 105 (net::ERR_NAME_NOT_RESOLVED): The server could not be f
go to tools, select options. click under the hood tab. then click change proxy settings. in the internet properties dialog, click lan settings. see if there is the check on automatically detect settings. then click ok. if same thing happens, it might be your antivirus or firewall blocking google chrome. try to clear cookies as well.
Feb 20, 2010 | Google Chrome
Even though Java is installed in my computer, it's having issues because it can't proceed w/ the current internet connections. I tried the website instructions to fix it, but nothing worked. Now, internet...
It sounds like you activated a firewall somewhere in there. Calm down and go find out about your proxy server if you were using one in the first place.
Also, what website instructions do you think you followed, anyhow? Lots of websites, lots of instructions...you've given no indication which one you chose.
Feb 09, 2010 | Microsoft Windows Vista Home Premium...
Sir i cant access yahoo on my system can you provide me any suggestion
I have 3 suggestions: 1. Go to Messenger>Connection Preferences> then, you choose either connection directly to the internet or connect via a proxy server, and then choose type of internet connection>OK>Sign in again... let's try this, may be you can solve this problem. OR 2. Check your internet connection, may be your connection encountered problems...or i think better you should check your firewall settings. I think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to sign in your yahoo messenger, check it out, may be it blocked your yahoo messenger from sign in. OR 3. Open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger again. I hope these can be helpful! Try these! Good Luck! Hope it was helpful!
Jun 11, 2009 | Yahoo Messenger
Login error 81003004fo yahoo
You might have some options to fix it: firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Or other way, open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.thirdly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003004” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful and it works to solve your problems.. Please kindly support me.. Thank You!
Jun 10, 2009 | Yahoo Messenger
Google Talk Error
First check your internet connection is active or not. Do the necessary internet setting in Google talk application.
Dec 01, 2008 | Google Talk
Ares (p2p sharing software) drops internet connction
I am not able to log in it says-
This program cannot display the webpage Most likely causes:
  • You are not connected to the Internet.
  • The website is encountering problems.
  • There might be a typing error in the address.
What you can try: bullet.png Check your Internet connection. Try visiting another website to make sure you are connected. bullet.png Retype the address. bullet.png Go back to the previous page. down.png More information This problem can be caused by a variety of issues, including:
  • Internet connectivity has been lost.
  • The website is temporarily unavailable.
  • The Domain Name Server (DNS) is not reachable.
  • The Domain Name Server (DNS) does not have a listing for the website's domain.
Dec 22, 2007 | D-Link Express EtherNetwork DI-604 Router
Can't set up DP 301U and still keep internet connection
I was able to solve this but it won't let me post here. sttmh01 --- hotmail.com if you still need the answer.
Dec 15, 2007 | D-Link DP-301U (790069251979) Print Server
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
