Question about Motorola Talkabout T5500 (7 Channels) 2-Way Radio
Lost power supply
Do you know the specs. for the t 5500 power supply output voltage and amp
  • Motorola Master
  • 1,654 Answers
We couldn't find the info regarding output/voltage. However, there is an online vendor offering replacement chargers/batteries for the T5500. Here is the link, look toward the bottom of the page for the chargers. http://www.csonline.net/crawford/motorola_talkabout_T5500.htm
Posted on Jan 30, 2009
Power Supply Output
No as long as the output voltage is the same and the supply amps is greater than 375mA.
Dec 20, 2012 | Office Equipment & Supplies
What is rating of Spin 50 Power Module. Lost mine
Should it be a power supply that outputs AC and converts to DC inside the speaker case, or is it a wall adapter the outputs DC straight to the built in amplifier?
Some speakers have the voltage and polarity for the plug on the back of the speaker where the power lead plugs in. As they are only small speakers of probably a couple of watts it may only need about 2 Amps or less. Higher current is fine as the amp will only use what it needs to work correctly but I would'nt go below 2 Amps.
May 06, 2012 | Labtec Spin 50 Computer Speakers
Output and power transformers specs
What??? There is NO output transformer for the Mg50DFX. The outputs are direct driven from hybrid stick TDA type solid state amp chips.
The power transformet is probably about 100 watt size and supplies two voltages... one that feeds a +/- 15 volt three terminal regulators... Probably 22 volts +/- to the regualtors and the other supply will be unregulated to the power amp chips.
Jan 28, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
My 600amp jump pack needle hasn't been charged in a while
Have a look at one like yours in store & see what specs are on plug in to charge. It will say Output voltage ..., then how many amps, or milli-amps, for example: ( output voltage 13.5 VDC @ 800ma.) Now find a charger/adapter, with same specs, and plug. Perhaps one your using is very minimal output, or lower voltage. Be sure polarity symbol is same on both too.
Jul 24, 2009 | 1999 Suzuki Vitara
Plugs for Astra Scanner 1220U
Ran across your request for information about the cables needed for hooking up the Umax Astra 1220U scanner. The scanner require a standard older version USB cable that hooks the scanner to your PC. The second cable is the Power Supply Adapter cable. The information listed on the Power Supply Adapter is listed below. P/N 490081-03 Input 120 Volt @ 60 Hz 0.3 amps Output DC 12 Volts @ 1 Amp Model # RWP481212 You should be able to get the scanner to work as long as you can find any power supply that has the listed Input/Output ratings, an adapter that will plug into the scanner. Hope this help you. disaksen
Apr 07, 2008 | Umax Astra 1220U Flatbed Scanner
Lost power adapter-help!
its 12V 1000Ma (1.0A) I work in radioshack... IN fact Im dealing with this problem as I speak... I need the Polarity for this however, otherwise theres a 50 50 chance this might get blown.
Dec 12, 2007 | Harman Kardon HK206 Computer Speakers
Motorola Talkabout T5500 (7 Channels) 2-Way Radio Logo
255 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
