Question about Toshiba Satellite 3005-S304 Notebook
Dim Screen I have a Toshiba Satellite 3005-S304 and the screen has become very dim. It has been a great computer until now. If you hold a light to the screen you can see the computer is operational. I have done some research on this problem and found in other models it is an inverter board but nothing on thid model. If it is an inverter board, how difficult is it to replace?
  • Toshiba Master
  • 4,338 Answers
It is the inverter board. It is usually about $40. It is easy to replace.
On this link you can follow the troubleshooting and repair steps for the LCD and Inverter boards.
http://www.laptoprepair101.com/laptop/category/lcd-screen-repair/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 29, 2009
    Sergeant:
    Champion:
  • 318 Answers
Inverters are really very easy to replace, with most laptops.,,you remove the front bezel plastic which surrounds the lcd screen,,and you will find the inverter near the bottom of the screen near the center, also you can remove the power button cover just below the screen but on the laptop itself , because it may be located there.
depending on various models.
also you may try www.retrevo.com to download a manual for this computer.
After changing the converter on satellite M305D-S4830 the backlight still very dim
i'm sure you ment inverter..if its working on external screen? it would seem. that you still need it replaced have u checked the ribbon cables?
Nov 23, 2013 | Toshiba Satellite M305D-S4830 Notebook
Toshiba tecra a2 screen backlight problem the is screen not lighting up at all but in bright daylight fully functioning screen can be seen could this be the lcd inverter and how difficult is it to replace
screen not lighting up is either the screen inverter or a broken tube inside the screen. Tubes don't break by themselves so a dim screen usually comes after a transport or a drop. I would replace the inverter first (just cause it's easy and cheap). eBay's a good source for inverters and screens and you ought not pay more than $5 for a used inverter and anything more than $30 for a used screeen would be considered tourist price. Tecra A2's are rare, but it's the same as the more popular Satellite A55's. Its screen should be a 15" XGA and would be the same screen as many other Toshiba Satellite models (A10, A15, A40, A45, A55) and Satellite Pro models (M10, M15), to name a few.
In my opinion, dim screens are 98% broken tubes and 2% inverters.
Jul 29, 2011 | Toshiba Tecra A2-S336 Notebook
At present my toshiba lap 3005-304 is slow at playing video, may I need drivers for video?
Welcome to Fixya.
If you need a driver for your display adapter just click on the link below. Select the operating system of your computer. You can also download the latest driver for your system.
Toshiba Satellite 3005-304 Drivers
Thanks for using Fixya.
Feb 23, 2011 | Toshiba Satellite 3005-S304 Notebook
How do i use the infrared on my toshiba satellite 3005 s304 laptop?
what device are you trying to connect to (u need 2 devices with infrared to connect and sychronization software)
u can use XP briefcase to accomplish this.
the IR port must be enabled as well ... check the BIOS settings
here is the user guide for reference
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=128928&rpn=PS302U&modelFilter=3005-S304&selCategory=3&selFamily=1073768663
Feb 02, 2010 | Toshiba Satellite 3005-S304 Notebook
How do i get the screen to light up more, its to dim?
Depending on how old your computer is, your lamps may be failing,
Or you may have reduced the brightness, look for two F buttons generally F7 and F8 for screnn brighness, hold down Fn or function button and tap F8 to increase brightness.
Jan 17, 2010 | Toshiba Satellite A75-S226 Notebook
I have a Toshiba Satellite A55-S1063 the scrren is dim but I can still see using a flashlight. I have had the back light replaced once it worked great for about 2 weeks and then went back to being very...
Hello !
Since the screen is dim, the display's inverter board needs to be replaced.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation, the inverter would be indicated.
Hope this helps.
Dec 01, 2009 | Toshiba Satellite A55-S1063 Notebook
I have a toshiba a45-s250. the screen is dim but
Have you adjusted screen brightness control as I have seen lots of Laptops with the screen brightness control "bumped" to min.!!!
Nov 20, 2009 | Toshiba Satellite A45-S250 Notebook
Monitor is dim
Sounds like your inverter is failing. The inverter takes the dc power from the battery and charger and converts to high voltage AC current for the backlight lamp inside the screen. When the inverter starts to fail, the display will sometimes blink, dim out over time, flash just get dark and stay that way.
Sep 28, 2009 | Toshiba Satellite A215-S7422 Notebook
My back light on toshiba satellite 1415-s173 laptop
Replacing a backlight is better left to the experts of experts - it is very, very, very specialized. On these models, a dim screen can also be a dead inverter - I'd try replacing that first. If replacing the inverter doesn't solve it, then just replace the screen. Don't even think about replacing the tube yourself.
Sep 07, 2008 | Toshiba Satellite 15" Flat Panel LCD...
Toshiba Laptop - Dim Screen
Hey, sounds like the back lights in the laptop are faulty, if it is backlights you should be able to see the whole picture but will be hard to see and dull.
Heres one website that sells them, aint sure if its the cheapest place, last time i think i was about £80 for them. which is alot of money but depends on the laptop make etc.
http://www.laptoprepair.co.uk/laptop-backlight-problem-dim-screen.html
Have a nice Christmas when it comes,,
John
Dec 10, 2007 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite 3005-S304 Notebook Logo
119 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
