Question about Nintendo Wii Console
Blank screen and remote will not connect, only flashes
Hi, First time I have turned the Wii on and I see a picture asking to slect language. I slect the language and the screen freezes. I then reset the console and all I see is a blank screen and the Wiimote will not turn on, only flashes the lights and goers back off again. Any clues? or should I send back to the shop for a replacement?
  • blcklabel Jan 31, 2009
    I have a modded Wii for 2 months now.. it works fine.. until this morning. i was play Metal Slug on it with my fren for about an hr.. then wen i woke up this morning to play Guitar hero.. all i got was a blank screen.. the Wii itself didn't load up anything on the screen.. i've tried hookin it up on another tv.. same problem. no sound no picture..
  • 26 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide................................................
Posted on Apr 07, 2009
Wont play games and screen keeps going blue
You have to turn on play game setting on the remote
Mar 22, 2014 | Nintendo Wii Console
My wii will turn on, but nothing shows up on the screen
Good news i had same problem and what i found out was that the wii bricked up an easy fix is to unplug ur wii from all cables then after 3 minutes plug only the power cable and see if ur wiimote connects but before dat remove sd and usb if the wiimote connects but u getno display then u have t afjust ur screen resolution hope this helps :)
Jul 03, 2012 | Nintendo Wii Console
When wii is turned on the start screen that shows the remot and asks to hit a comes up in three different languages can not move pass that? Remotes not responding
try syncing your remote by doing the following (and make sure batteries are good)
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
Jan 16, 2011 | Nintendo Wii Console
Stuck on Language settup screen
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
jeonatumi10
Dec 30, 2009 | Nintendo Wii Console
Wii problem - Can't get past Select Language screen
keep getting a error has occurred,press eject button and remove the disc,then turn wii console off and refer to manual cant get past this.
Dec 25, 2009 | Nintendo Wii Console
Our wii remote wont turn on. we tried new batteries and all it does is the blue lights flashes and turns off. What is wrong and how can we fix it
Sounds like it's not synchronizing with the infrared bar. That might've come loose. Double check to make sure that's plugged into the Wii. If that's not connected the Wii Remote will not stay on because it's not connecting.
Oct 14, 2009 | Nintendo Wii Console
How do i sync my remotes with my nintendo wii, four blue lights flashing but not working with picture on screen, cannot get off first screen when wii turns on. cheers
You need to press the red button under the protection cap for the SD card reader AT THE SAME TIME AS the one under the battery protector on the remote. Sometimes, it takes more than one try to get it to work.
Hope this helps,
Regards
Aug 02, 2009 | Nintendo Wii Console
Blank Screen
it could be the batteries or your wii home button is broken so when u press it the wii remotes turns off can u help me with my wii problem
Aug 21, 2008 | Nintendo Wii Console
Wii turns on but has no picture or sound
You could try resetting it by taking out the motherboard battery.
It is on the bottom at the back under a plastic cover.
You may need a tri wing screwdriver to remove the cover.
Try taking this out for a couple of hours and it will reset it.
Hope this helps,
Mowcius
Jul 04, 2008 | Nintendo Wii Console
Problem setting up the Wii
Try aiming the remote at the screen ( Providing you have your sensor set up) till you see the little hand pop up and use that to click on the English tab with the A button.
I hope that helped...
May 07, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
141 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
