Question about Gateway NX100X Notebook
Changing out the cooling fan?
My NX100X fan is really loud and i like to check out the fan, but don't know how to get to it. I get stuck trying to take the cover off. Did i forget to unscrew something, can someone help???
  • 1 more comment
  • kyban4501 Jan 29, 2009
    I unscrewed all the screws (that i can see) underneath the laptop, but is unable to take the top cover off to get to the fan. Basically I'm trying to get to the fan, and is unable to do so. I can send a picture of how i disassemble the laptop if anyone like to see it.
  • mithila
    mithila May 11, 2010
    Here is some great source to solve any kinds of laptop's problem.
    » Hp Laptop's Solution » Compaq Laptop's Solution » Acer Laptop's Solution » Dell Laptop's Solution » Toshiba Laptop's Solution » Asus Laptop's Solution
    » Gateway Laptop's Solution » IBM Laptop's Solution
    Here is some another Great source to download any kinds of laptop Drivers.
    » Hp Driver's Download » Compaq Driver's Download » Acer Driver's Download » Dell Driver's Download » Toshiba Driver's Download » Asus Driver's Download » Gateway Driver's Download » IBM Driver's Download qqqq-59
  • Mike Gagnon
    Mike Gagnon May 11, 2010
    Which cover are you reffering to?
I have a Yamaha 400 big bear and cooling fan won't
Start by checking the fuses... If they're fine the start tracing the wiring from the fan. Look for any burn marks, pinches, etc... If in doubt I'd recommend taking it to a professional. It's really easy to mess things up if your not sure what your doing
Mar 20, 2013 | Motorcycles
Fan running continuously
the fan in your computer is constantly running to cool down the cpu and it is normal for it to increase it's speed, your fan should run quietly even it increases the rpm. But if you hear a loud noise in the fan, i think there's something wrong with it. I suggest for you to check the fan if it's coming in contact with anything. If the fan is visible while your laptop is operating, you can observe it to know what is really happening. I don't know what type of fan hp uses on their laptops, maybe something is loose already on the fan so better check it or bring it to a service center.
Aug 06, 2012 | Computers & Internet
My laptop has buzzing noise from the place where air comes out from. It has not been like this and I wonder what can I do to solve it? It's really loud buzzing noise and changes intensity from time to...
It sounds like the cooling fan is going bad.. when the cooling fan starts going bad it makes a loud noise and sometimes it doesn't even run. Here's the link for a fan for that specific laptop:
http://www.ebay.com/sch/i.html?_nkw=Toshiba+Satellite+L645D+fan&_sacat=0&_odkw=Toshiba+Satellite+L645D&_osacat=0&_trksid=p3286.c0.m270.l1313
Please let me know ifthis was helpful and if it solved the problem! Also if the information providedwas helpful, please click on the appropriate thumbs to make us aware that theproblem has been corrected or that the information provided helped you with theproblem.. Thank you and Good Luck.
Sep 11, 2011 | Toshiba Satellite L645D 14 in PC Desktop
HI, my coolermaster laptop cooler, the U2 with 2 optional fans have been acting loud. only one fan has been acting up. it makes loud noises while the other one is silent. like a grating noise kind of. cant...
Sounds like the fan is going out. I would take it back to the store and swap it for a new one. Alternatively, if you decide to keep it you can try to put a drop of 3-in1 oil in the center of the fan to prolong and/or fix the noisy fan.
May 26, 2011 | Cooler Master NotePal U2 Notebook Cooler ...
I have dell 3300mp,when I turn the power on it makes a very loud noise. It does not make the sound in standby or cool down. It does work and display a signal okay, but it is very loud. Sound like a fan?,...
The main fan that cools the lamp is mostly high speed when the unit is running. when it shuts down it slows the fan down, until it stops in standby. So the noise is only really loud when it is showing a picture.
try setting the fan to eco mode (slower running) and see if the noise is acceptable. If it is still too loud then you will have to replace it. Have a look at the fan and see if any of the plastic blades are missing.
Mar 26, 2011 | Dell 3300MP Multimedia Projector
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
The cooling fan is really loud and it has an
you can put lubricant oil on the center where you can found the washer holding the motor.
Apr 03, 2010 | Dell OptiPlex GX280 PC Desktop
Hi I have vaio VGN CS215J it makes a lot of cooling noise how can I solve this problem... I bougth from best buy it has 1 year waranty if the problem is cooling fan I don't know if they change the cooling...
The warranty should be handled by Sony. Check your documents, as some brands only offer 90 days, while stores sometimes have their own extensions for longer periods. Best Buy can also advise which one it is.
Sep 27, 2009 | Sony (1-763-658-11) Laptop Cooler, CPU...
Computer is loud when watching videos
this is due to the unit trying to keep the video card cool. this is set by the laptops bios settings. make sure you are not obstructing the fan intake and exhaust port.
May 26, 2009 | HP (D6021-63034) Fan Assembly
My laptop turns on and then it turns right off!!! HELP!
hi there
It seems your laptop computer is not cooled properly which might be beacuse of a broken cpu fan as you mentioned it makes loud noise.
The reason your laptop turns off by itself is because theres a circuitry built on the motherboard which power offs itself if the internal temperature raises, this is a safety feature to prevent your computer getting burnt.
Please avoid using your computer and take it to a shop where you can have it checked for cooling.
hope this answers your question
May 30, 2008 | HP Pavilion dv1000 Notebook
Gateway NX100X Notebook Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
