Question about Olympus Camedia C-350 Digital Camera
Will not close
The zoom lense will not close there for the slide plate to turn camera off will not shut...I changed batteries numerous times to make sure that was not the problem and still can not get it to work. Camera is not working at all. Please help.
    Genius:
  • 2,985 Answers
This is a case of the motor mechanism failing for some reason. An economic repair is not likely Replace the camera
Posted on Jul 31, 2007
SOURCE:
How to disarm Fujinon SRD-92B Zoom Rate Demand
Remove end plate. Remove rate control knob and pot. Loosen up three set screws on housing, center zoom control, and slide entire assembly out the end of the housing. Where will you find a replacement spring?
Feb 28, 2013 | Fujinon Inc SRD-92B Zoom Rate Demand with...
Samsung nv10 digital camera, the lense is stuck in zoom position. if i turn on my camer i cant get it to close and then it shuts off
Hi! As a first course of action please remove the battery and press hold the power button for 10secs. while the battery is removed. Install the batter, turn it on and see how it goes.
Oct 07, 2010 | Samsung NV10 Digital Camera
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Yep. another lens stuck.
it depends on what the problem acctually is. In my experience with cammeras such as these, a problem of this nature is not worth the trouble, but if you really like the cammera then take the covers off by removing the screws around the cammera body. Start by removing the back peace. you wont need to remove the door for the batteries or the two screws around the mount on the bottom of the cammera that hold the screw tripod mount in place. once you remove the backing you will expose at least one more screw on the side that holds the front cover on. you will want to very carefully remove the wires for the backing by pulling back the ribbon cable retainer clip and the ribon cable retainer clip must be pulled back carefully for the shutter switch as well when removing the front pannel of the cammera. Unplug the yellow wire for the micro switch in the front if applicable and then you will have exposed the lense. remove the screws holding the lense assembly in and then look around at the operation. THERE IS A CAPACITOR IN THE FRONT OF THE CAMMERA THAT WILL SHOCK YOU!!! DO NOT TOUCH THE BOARD. I've been shocked by the thing at least 3 times today so dont get all hasty. you will probably notice one of the gears are stuck or something you can buy a new lense assembly and install it but it is probably just as much as the cammera. I would sugges trying to repair it or if it is too damaged throw it away. It depends on what you find. you can look up small gears on line but it also may just need to be set back in or cleaned. You may also want to replace the cammera battery while you are in there. When removing the back pannel start from the bottom of the cammera and slightly hinge up and pull the backing away genly as to not snap the retainers in the upper part of the cammera or yank out the ribbon cable. REMOVE THE BATTERY BEFORE YOU BEGING. WITH THE BATTER REMOVED THE CAPACITOR WILL STILL SHOCK YOU. be careful.
Aug 16, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
Zoom error
Hey MBB722,
What is most likely going on is there is something stuck in the lens obstructing its movement (i.e. sand). I don't know what you have tried and what you have not tried you can try placing the camera on a flat surface with the lens pointing upwards, and then press and hold the shutter button and while doing this turn the camera on. If this doesn't work you can try removing the batteries and waiting a minute or two and then reinserting. If these suggestions don't work you should have it looked at by an authorized service technician such as bringing the camera to a Geek Squad® precinct at a Best Buy™ store and they can send it out for service. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 01, 2008 | Fuji FinePix F470 Digital Camera
Lense does not close
sir, ur camera lens mechanically stucked or gears problum ,this is repairable
Apr 12, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Automatic zoom
auto zoom will only work while the build-in wide-flash adapter is slided inside.
Apr 05, 2008 | Nikon Speedlight SB-600 TTL Flash
Zoom and the camera shuts down
lo m8 sounds like a software problem m8 but cant be sure without taking it apart i would look for any damage to lense or switch for zoom.if no fault is found then i would try and find the software for it. but if you want more info or would like to get it done from somewear then try tech sapport at this site http://www.mobilephoneservicecentre.co.uk/
Feb 27, 2007 | BenQ DC E600 Digital Camera
Coolpix 8800 shuts down
Make sure to use good NiMH batteries. Another possiblity is a problem with the card. Borrow a card and see if it has any effect. check to see that the pins in the card slot are all aligned, none out of place. check that the card door and the battery door close firmly, with some pressure. The camera can shut down when it has a problem detecting that the doors are closed. When it does turn on, play with the zoom without taking pictures, zoom in and out, if during zoom the camera shuts down then you might have a lens problem, something is malfunctioning in the lens mechanism and the camera shuts down to prevent damage. Good luck
May 19, 2006 | Nikon Coolpix 8800 Digital Camera
Stylus 300 won't stay on??
In the cameras I own, there is a setting where you can adjust the time the camera stays on. It's usually in the set-up screen. Is that setting miss-set?
Sep 12, 2005 | Olympus Camedia Stylus 300 Digital Camera
Olympus Camedia C-350 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
