Question about GE Profile WPRE6100G Top Load Washer
My ge washer wpre6100g clicks during agitation part of cycle...
I hear a little irregular swishing but no agitation and this sound is exactly the same in all other types of cycles, ie. cottons, casual, handwash or load type, or any of the other settings. seem to run ok during any other parts of a cycle, ie. spin, drain, rinse...
  • rketchens Jan 30, 2009
    Thanks, will see tomorrow. Just washing away on the handwash cycle till then, lol. Can't get her to stop for repair at the moment. Maybe handwashing works ok. She says everything is clean........I think the wrags i use one the Bike will need a litle more, lol.......
    Rob
    President:
  • 1,314 Answers
Sounds like the agitater drive is stripped its a plastic piece under tha agitater you just grab the agitater work your fingers under the edges and **** up on it and it snaps off then remove the 5/16 screw put a new block on and snap the agitater back on
Posted on Jan 29, 2009
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
Agitator will not work spin does
can you hear it trying or does it try with a grating sound,most of these have a plastic drive coupler underneath the agitator and this or the thrust bearing could be your issue,you need to remove the agitator parts first(and run a wash cycle without any clothes in the washer) and see if this is the problem,as with the agitator off the stem(both inner and outer) should run when held by hand during any cycles and there should be resistance as in no slipping during holding by hand,then if you still have problems then its further below this area
Nov 07, 2010 | GE Profile WPRE6100G Top Load Washer
Ge washer won't agitate
If the washer won't agitate at all, but the motor and belts are turning,
then you may have drive coupling or transmission issues. In this case, it
is well worthwhile to have a technician check the machine to verify this.
Sometimes, the base of your agitator can strip out, especially from
overloading. In such a case, the splines are damaged inside the agitator,
and can be seen after the agitator is removed.
If you can hear the motor running, and the water is moving a little bit, but not like normal where the clothes are being worked around you might just have worn out agitator dogs. This is a really easy 15 minute do it yourself fix, and the parts are less than $10 and widely available. Here is a how to article - http://zenfixit.com/repairs/appliance-repair/washing-machine-agitator-clutch-repair/
Feb 01, 2009 | GE Profile WPRE6100G Top Load Washer
Very loud during the spin cycle
the top bearing has gone bad you are looking at replacing the transmition and tub seal about 200 dollars in parts the labor is a little tough also you got to completly disasemble the machine to do this may be best to get a new machine
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
During wash cycle the hub nut that is located under the agitator comes loose. It has to be tightened after each wash. GE Profile Top Load Washing Machine
replace the hub nut and the washers under the tubbe sure to tighten really tight if it comes loose again you will need to replace the transmition
Jan 15, 2009 | GE Profile WPRE6100G Top Load Washer
Squeaking Top Load GE Washer
I bought a new GE Washer GTWN5050MWS yesterday. From the first load it squeaked each time the tub moved back and forth (no agitator in the infusion type) It is a quick squeak and kind of resembles a cat getting it's tail under a moving rocking chair. I checked the entire owners manual and it describes several noises and not one of them describes what my new washer is doing. It does not make this sound except for when it is in the wash cycle. Spinning is quiet, and during the agitation of the rinse cycle it is a much more subdued squeak. But during the wash cycle it is not acceptable.
I called GE this morning and they told me it was normal operation for all infuser types of their washer to make this noise. Tomorrow I will be taking it back for a full refund.
We purchased this machine because our 2-year old front loading GE washer broke down (discharge pump I think) and to get it fixed usually takes a couple of weeks. We thought it might be better to have a 2nd washing machine instead of paying the laundry mat. It took a month to get the last one declared unfixable in 2008. Maybe I was wrong. But this is very bad luck to have a brand new washing machine squeak so loud out of the box.
Mar 15, 2008 | GE Profile WPRE6100G Top Load Washer
Just spins during the wash cycle
Sounds like the agitator got dislogged during moving. In some machines the design allows for the agitator to move up and down alittle too much. Try this and this is only a guess. With the machine empty push down firmly on the agitator and move it back and forth as you do. You might hear a little "pop". If it does, try running the machine again. If it works problem solved, if not tell what happened.
Jul 17, 2007 | Whirlpool GSC9455 Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
213 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
