Question about Canon PIXMA MP470 All-in-One Printer
My printer quit working and is showing error 5100. I have tried everything and still can't get it to work
  • cheryldance Feb 01, 2009
    I changed my ink cartridges (This model really uses up the ink). Clerk told me to get another printer OR to install an empty color ink cartridge so that it can't add color ink to the black ink when printing in black only. I never used color, but the printer ran out of color ink anyway.
    When I installed the new ink cartridges, which I have done many times, I got the flashing lights and error code 5100. I have tried and tried with cleaning, shutting down, vacuuming, researching the net, etc., to be able to use the printer. I want to do my taxes!
I also have a code 5100 error showing on my MP470. After I hit the print button it stops after running for maybe 1 or 2 seconds. I have to remove the paper from the back. It always shows smudged ink and crumpling in upper left hand corner.
I contacted Canon tech support and they answered with some instructions to see if it would correct the problem. They said if it didn't correct it, it was a hardware problem and since I was under warranty I could exchange it....for a refurbished model. I have sent a request for an exchange. So far no answer back.
Posted on Jan 31, 2009
There's an error 5100 appear on my printer canon mp770. I need some help,please.
Problem You are unable to print and receive the message Error 5100 on the computer or printer display screen.
Cause Error 5100 is a carriage error that can usually be fixed by using service mode and flushing the printer heads when it has a blockage.
Solution Try the following:
If this doesn't work then the printer may need repair.
Canon Printer Error 5100
Oct 19, 2012 | Canon LASER SHOT LBP-2900 Printer
Canon pixma mg2120 error 5100
I just bought this Canon PIXMA MG2120 PRINTER about 2 weeksago, I've been able to print untillast night, it's giving me error message 5100, what do I do to fix this?
Jul 15, 2012 | Canon Office Equipment & Supplies
Error 5100
The 5100 error usually shows up when your computer system files are damaged. There is about a 94% chance that this is the problem.
Follow these steps to fix the issue:
Step 1: Download and install Error 5100 Repair Tool
Step 2: Click the Scan Button
Step 3: Click the Fix Button and you're done.
Hope this works for you!
HelpDeskMan
May 21, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Service error 5100 on Canon IP 2770
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Feb 01, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Ip 3000 canon showing service error 5100, tried to reset but still flashes amber. Tried nearly everything. Cartridges still full
Carriage error [5100]
Solution (Replacement of listed parts, which are likely
to be faulty):
- Carriage unit (QM2-1250)
- Timing **** strip film (QC1-4284)
- Logic board ***'y (QM2-1520)*1
- Carriage motor (QK1-0545)
Aug 04, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Getting a 5100 error . put in new ink and camera card it works till hit print then shows an error -5100
5100 means the carriage is not moving freely because of paper scraps inside or grease or ink on the encoder strip behind the carriage. you can try cleaning the strip gently with just a damp Q-tip, moist with water, and look inside for scraps or things that don't belong.
Nov 04, 2009 | Canon SELPHY DS810 InkJet Photo Printer
Everytime I try to print Error 5100
Hi, Error E22 5100 is a carriage error. Check that nothing is stopping the cartridges from sliding back or fore acroos the silver bar inside the front of the printer.
Nov 05, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Service error 5100
may be the driver are not installed correctly ... just try reinstalling the drivers ... and make a check that you have inserted the ink cartilage or not ...
if not insert it and then give try ... it may work ..
if problem persists then call the service rep ...
Feb 07, 2008 | Office Equipment & Supplies
Error 5100
Maybe you haven't put your ink carterages in properly, I had the same problem and fixing their position solved it
Oct 08, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Canon PIXMA MP470 All-in-One Printer Logo
145 people viewed this question
old marine
old marine
