Question about iLO 3200 32 in. LCD Television
Ilo input source
Even with a universal remote I am unable to change the input source to watch DVDs or anything else. Dogs chewed up the primary remote. Any way to change input to use a DVD player?
  • Anonymous Apr 05, 2009
    I have the same problem. There is no INPUT SOURCE select button to be found on the set, front or back. Its also not in the menus along with the picture and channel programming controls.
  • Anonymous Apr 06, 2009
    salve
    Problem Solver:
  • 10 Answers
On the top of the set, there should be a button on the left called SOURCE. You should be able to switch inputs with that. If that does not work, your set is broken, and you will need to return it to Walmart.
Posted on Jul 27, 2007
SOURCE:
Hi, my RCA CRC311 BT turns on my Sharp television, changes the channels, etc, but it won't switch to video mode, even when I hit input. It is an old TV, but I used it to watch videos, dvds and play games...
Unfortunately you will not be able to switch input.
I also have a Sharp, I have tried 5 different universal remotes. None will switch input. I guess that function is not provided properly.
Sep 18, 2010 | RCA RCR311B Remote Control
Need to switch to dtv from reg tv but dont have fac. remote
most universal remotes will only do basic functions on your tv like changing volume or channels only some will do menu functions or change input source. if you have a universal remote with a input or source button you can try it some cable and satelite remotes have this function and are discribed in the user manoal. If all else fails you can order a original remote from the manufacture or your local tv repair shop
Apr 27, 2009 | iLO 3200 32 in. LCD Television
Tried connecting DVD player to ILO 27 in, no go
go to video on your remote, then go to composite... it should work on composite mode. Took us a while, don't feel bad. Hope that works for you.
Nov 14, 2008 | iLO 3200 32 in. LCD Television
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
ILO Recorder DVD05R - Playback jumps 10min, 20 min and more...
Does the disc still play in other dvd player? My ILO has always been picky to play rentals so I just have a cheap COBY player hooked up to front inputs of my ILO. I use it to watch the dvds, only use the Ilo to record. Saves wear and tear on my ILO but cannot find a universal remote to operate them both and my tv. If it still records okay thats what I would do, just watch the discs in a secondary unit. Sounds like time to start shopping for new recorder.
May 04, 2008 | iLO DVDR05 DVD Recorder
Can't change output source and tv sensor wont work
souns like the ir sensor board is gone, shopjimmie.com may have one ,they are probably around 15 bucks and real easy to change ,its one connector i believe ,i have not found any universal remotes that work with ilo yet either,good luck i hope i was of help
Apr 23, 2008 | iLO 3200 32 in. LCD Television
Remote control code for universal remote
need the code for ilo dvdr05 remote
Jan 01, 2008 | iLO DVDR05 DVD Recorder
iLO 3200 32 in. LCD Television Logo
197 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
